125-200cc Sick of my new bike not running!!!
Discussion in '2 Stroke' started by Ronalderic, Nov 24, 2014.
  1. Ronalderic Husqvarna
    Wr300
    Ktm -indian -kawasaki
    Have a leftover wr300 with 5 hours on it- dealer diagnosed w needs stator changed stator - coil cdi- and regulator still will not run!! Misdiagnosed maybe? Crank seal?? Centercase?? Had bike for 6 months ran forone month??tired of it not running thinking of parting brand new bike out!! Any suggestions
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    does it have spark? have you checked the timing?
  3. HusqRacr Husqvarna
    Escondido, CA
    TE511, 10' WR300, 2015 FC450
    Ducati 998, KTM 520EXC
    only need 3 components to run. Spark, fuel mixture, and compression. Whats not there? If they are all there- then the timing is off, way off. 2 strokes are pretty simple and easy to diagnose. Give a little more detail and we'll see if we can help you out. (from a Ducati-Husqvarna tech)
    wrtimmy, Motosportz and jmetteer like this.
  4. Ronalderic Husqvarna
    Wr300
    Has intermittent spark --timing/ carb was checked by dealer all ok --i have 800.00 plus in repair and it still does not run?? Could it be crankseal or center case?
  5. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    yes check spark, check compression and leakdown, check fuel flow to carb, check carb float and jets, make sure slide returns properly.
    fit an inline fuel filter.stator will have two windings one for lights one for ignition.
  6. Motosportz CH Sponsor
    trigger on the ignition not adjusted right or going bad?
  7. Crocus Paper Husqvarna
    UK
    WR250
    Scorpa 300 Aprilia Dorsoduro 750
    Wiring to engine cut out switch?
  8. rancher1 Husqvarna
    WA
    I would be at a different dealer that knows husqvarna.
    HusqRacr and fletchman45 like this.
  9. fletchman45 Husqvarna
    park rapids
    These are a great bike with a dated but superb and typically super reliable engine. Please get to a dealer that knows wtf they are doing !! Being a carryover is there not some type of warranty???? This bike will be a good bike once your problem is sorted. I can under stand the frustration involved. But seriously get it to a reputable dealer. That engine has not changed a lot since back when it was stamped cagiva. Good luck and let us know what it was. Is there another bike available that they could swap a few items fie process of elimination? But in reality they should be able to figure it out....
    Oldscool likes this.
  10. Ronalderic Husqvarna
    Wr300
    Tried a bonified " husky dealer" that was wagner powersports charged me 250.00 for nothing- actually said it was running and in fact it did not run at all??!!
  11. HusqRacr Husqvarna
    Escondido, CA
    Does your bike have the lighting kit installed? ...if yes, properly..?
  12. TROFFER88 Husqvarna
    Camas Wa
    Check you plug cap , been known problem on these bikes
  13. DTX915 Husqvarna
    wr125
    kdx200 tt500 yz450 klx125
    Wagner out in eastern mass ?
  14. Norman Foley Husqvarna
    Husky Dealer who knows Italian Huskys in New England? Unfortunately, that hasn't been around, since Morel's closed about 12 years ago.....
  15. Glenn haynes Husqvarna
    western pa
    2012 wr300
    13 yz250f 08yz85 11ktm 65 09 ktm65
    I had a similar issue when I bought mine,it was the wiring chafed by the turn by the coil. It was 6mo old when it happened to me. I wanted to burn the bike to the ground.took me forever to find it. Now I can't imagine riding another bike.love it
  16. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Are you mixing your gas with 2T oil?
    Ronalderic likes this.
  17. DTX915 Husqvarna
    wr125
    In New England its American Trike And Motorsport, they ride and race them. Try 603-354-7740 they have help out at some of the J-Day events and carry some spares.
    Also REP out in West Springfield Ma raced a Husky last year and can help. They worked on my shock and hand delivered one to the track for the Mrs one time, 413-737-0355
    Last is Roost power sports down in Ct, but only if you have to. Guy on the start line told me he bought red Husky's, just to get parts for his customers, have no idea if that's true.
  18. Parh 474 Husqvarna
    Newbury Park, CA
    '73 Cr125, '06 Cr125/144
    Ossa, Bultaco, Puch, Maico, AJS, Yam
    Is the pilot circuit in the carb clear?
  19. DTX915 Husqvarna
    wr125
    Had a trigger crack on mine , once replaced dealer discovered it was firing 180 degrees off. From what I was told they can program it. Mine has been fine since.
  20. Ronalderic Husqvarna
    Wr300
    The whole problem was wagner powersports according to dealer who fixed it !!-- apperently they installed flywheel wrong and shearedkeyway!! They also charged me 250.00 to mess my bike up!! Dont go there!!!
    kzoo, HusqRacr and justintendo like this.
