silicone brake fluid?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by steadydirt, Apr 11, 2016.
  1. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
  2. bikesparky Husqvarna
    Townsville Oztrailia
    FE501
    Superduke 1290
    You can't! Dot 4 is the same or can't be replaced by 5.1.
    Silicone Dot 5 is strictly for that application and can't be used in Dot 4 or 5.1 or the other way round!
    The fluids don't mix and the seals neither.
  3. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Dot 5.1 supposedly needs to be changed frequently due to absorbing moisture more. Some good high temp racing dot4 like maxima should be a good improvement.
  4. bikesparky Husqvarna
    FE501
    Superduke 1290
    Both Dot 4 and 5.1 (and dot 3) absorb moisture due to being glycol based. I never have failed brake (or hydraulic clutch) parts as I change the fluid on all my bikes at least once a year.
    When I changed it on the husky after I owned it for about 8 months the fluid was just rank! Don't know what they use OEM but it was bad, specially the clutch side.
    Dot 5.1 has an higher boiling point, that's why I use that.
    juicypips likes this.
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    seems like alot of effort just to eliminate a refresh every 12-18 months. I find the gycol stuff fine on bikes as the systems sealed but on cars its open vented so it will absorb more moisture.
    bikesparky likes this.
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i run dot 4 in everything..nice upgrade from 3 and no mixing issues. cars and bikes..
  7. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
