Silly fork guard question?
Discussion in 'TR650' started by Rayzor61, Jun 5, 2014.
  1. Rayzor61 Husqvarna
    Pennsylvania
    Stada 650 - on its way
    Triumph Explorer Tiger 1200
    Where can I get them? Looked all over the internet and can't locate a set for a Terra to put on my high fender Strada......
  2. hasenpfeffer Husqvarna
    CO
    Dealer, or ktm-parts.com. I ordered from Bill's Motorcycle Plus in Oregon. I seem to recall the guards being the same part for another husky model.
    Terra 15 80A0A8481 1 LH leg protection
    Terra 16 80A0A8481 1 RH leg protection
    Edit: Hmmm, seems the parts book has a typo. RH is 80A0A8482, I believe.
    Edit: Yes, same part as a 2011 630 SMS, black or white.
    M 24 80A0 A8482 1 Guard R.H. (BLACK)
    M 24 80C0 A8482 1 Guard R.H. (WHITE)
    M 25 80C0 A8481 1 Guard L.H. (WHITE)
    M 25 80A0 A8481 1 Guard L.H. (BLACK)
  3. Rayzor61 Husqvarna
    Pennsylvania
    Thanks, great news, now to find risers that don't require all new cables and a SC tall seat.
    OTHERS CAN STILL CHIME IN. I WOULD THINK HUSKY WOULD SELL DIRECTLY FROM THE TERRA???
  4. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Check the interchange parts thread. Dutchgit did a high fender setup last week I think, on his wife's Strada. He used KTM fork guards and a KTM 85 fender. If the KTM fork guards bolt straight on, then Honda ones should work as well, IIRC.
    The KTM ones wrap all the way around, but Cycra has wrap around ones that unclip and you can put on without removing the forks. Had some on my 08 KTM -- that also listed Honda CRs on the fitment chart.
    Moff69 likes this.
  5. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    Fork gaurds set me back a whopping $14 from my dealer. The part number for the hardware kit only includes hardware for one side, so you'll need two sets. Or just get hardware sourced locally, it isn't anything special. You'll need to re-route your brake cables for the install. More info on page 3 of this thread
    http://www.cafehusky.com/threads/terra-fy-your-strada.34142/
    Check out the 2" Powermadd risers. I'm running them and have not needed to replace cables. You will have to re-route your cables though. It seems that Husqvarna routed them the most bass-ackwards way possible upon assembly.
    If you're a tall guy, you might try Touratech's adjustable footpegs for the F800GS. They are direct replacements and make a huge difference. However, depending on your foot size, you might find yourself wanting to move your shift lever too.
  6. glitch_oz Husqvarna
    AUS
    Strada
    Here's the list as per Hall's last week (without the bolts and including another brake-like guide+bracket which I'll use
    for a re-routed clutch-cable).
  7. Rayzor61 Husqvarna
    Pennsylvania
    wow, perfect site but whats with the special handling charge of $68?
  8. glitch_oz Husqvarna
    AUS
    Strada
    Fixed
    That was postage to Australia, doesn't apply to you :-)
  9. Rayzor61 Husqvarna
    Pennsylvania
    got everything but the retaining ring and the fenders of coarse
  10. glitch_oz Husqvarna
    AUS
    Strada
    You don't need the ring and "cable bushing" for the high-guard changeover, I only added them as I've re-routed the clutch cable and don't like the chance of it getting jammed between the headlight shell and steering lock now, when the bars are moved lock-to-lock. There's a remote chance of the clutch-cable hitting the sensor-ring cable-nub on the steering lock, possibly causing EWS errors.
  11. Rayzor61 Husqvarna
    Pennsylvania
    I found out the hard way after I just read your receipt to Bob (less the fenders I already have). The retention ring was back ordered anyway.. Thank you a great deal
