125-200cc Silly piston question....
Discussion in '2 Stroke' started by skingston, May 14, 2015.
  1. skingston Husqvarna
    wr250
    Honda crf250l, Victory Highball
    Hi all, stand by for a stupid question.....
    I took my WR250 (2004) engine apart a little while ago for a top end rebuild.
    Like a fool, I didn't take any photo's before I dismantled things, assuming all was pretty obvious.
    However, when my new piston arrived a couple of weeks later, I realised it doesn't have any marking on it, so now I'm not sure which way round it should go.
    As those who have rebuilt these engines know, there's a cut-out on the the skirt, so my question is, should that cut-out face towards the inlet or outlet ports ?
    Thanks for any help! :)
  2. Comanche87 Husqvarna
    Littleton, CO
    1999 CR250
    The cut out in the skirt goes on the intake side. It's there to line up with intake port into the crankcase. :thumbsup:
    Petar likes this.
  3. skingston Husqvarna
    wr250
    Thanks for that, the confirmation is much appreciated ! I was pretty certain I'd put it back together the right way round, but have been really struggling to understand why the engine had no power since I rebuilt it.
    It would start OK, but bog down in the mid range.
    Again, my own fault, I made a bunch of changes and have been chasing my own tail ever since trying to work it out.
    Much of what I read suggested it was likely down to carb set up, but that was one of the few things I'd not really touched !
    Hence I finally started to wonder if I'd done something really stupid when putting the engine back together.
    Anyway, before getting my computer out this evening, I headed out into the garage and decided to put the old, rusted,bent & holed exhaust back on. I'd replaced this with one off an '05 Husky as the only one I could find cheap at the time. Anyway, it turn out the bike runs fine (relatively) with the old exhaust on. Blowing through the '05 one it seems much more restricted, so I'm guessing it may have a cat in it?
    Who knows, but I now need to a decent '04 exhaust it seems.
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Try fmf they do a bunch of sexy pipes, pro circut or doma may do one for your bike, could be different expansion profiles causing rich running.
  5. skingston Husqvarna
    wr250
    Sadly the new exhaust route is not a cheap option in the UK, especially when the bike was a cheap 2nd hand buy.
    May have to go that way though since replacement 2nd hand exhausts are in short supply too.
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    I too am in the uk i have a fmf gnarly in mine, bought from racespec.
    No not many things husky are cheap, go jap for that my friend.
    justintendo likes this.
  7. skingston Husqvarna
    wr250
    lol, fair point, guess I might have to take the hit and buy something shiny!
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup, you may be able to get a ktm pipe some on here use the 200 pipe on their 165's
    If you do find a 250 ktm pipeit may need atouch of fettling to fit in the frame and beneath your shock resivour,and some tabs may need to be welded on for mount locations.
  9. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    suss out a pipe repairer. there's bag loads of them. ive mashed pipes to where the bike will not run. Finish Line, PCPR, RPS Motorsports etc can do the trick.
    Finish Line did the best work in the day IMO. they also do a bang on job of decoking them. not sure if they sill exist.
    http://www.piperepair.com/
    (and yes im using brit vernacular so you pom's can understand me!)
  10. skingston Husqvarna
    wr250
    Thanks guys, looks like I have some options there.
    Been suggested I could take the restriction out of the '05 pipe I have, so I may have a go at that.
  11. pvduke Husqvarna
    ... on the gas...
    giver a go mate, once done, you'll be well "chuffed"! (love that word...hehehe)
  12. skingston Husqvarna
    wr250
    He he, not doing a bad job with the vernacular !
    I think that is what I'll end up doing. Not quite sure where it'll need cutting though.
    I performed an unscientific test by dropping a plumb weight down each end of the pipe, from which it would seem to be restricted at each end of the expansion chamber.
    May have to defer to a professional, not sure I trust my own welding ability.
