Slick offroad wash
Discussion in 'General (Main)' started by MOTORHEAD, Nov 22, 2010.
  1. WHITEROCKET5.9 Husqvarna
    central illinois
    yall wash your bikes?? :D
    water racer and robertaccio like this.
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    most of the time its just a hose rinse, airfilter swap and chain lube and go-go-go, from 10 feet away or more the bike looks good and after 10 minutes its dirty anyway.......
    kk273 likes this.
  3. Runner Husqvarna
    Los Angeles, CA
    2006 TE510
    Simple Green Extreme works fine. I avoid the standard Simple Green as I'm told it is acidic and will etch exposed aluminum surfaces. Simple Green is great for plastic parts and a chain soak before re-lubricating.
  4. Motosportz CH Sponsor
  5. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I use to use tire cleaners some years back and always though they worked really good. If these Huskys were aluminum frame I'd probable still use it.
  6. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I intend to wash mine someday but I've only had it for a year so I don't want to rush it, besides that's what creek crossings are for.
    ozzie and Bagman like this.
  7. pahusky Husqvarna
    Hummelstown, Pa
    '14 TC250
    '12 250XC '09 1200GSA KLR650
    This stuff is great for the plastic after it's washed up.
    Look it up...A good coating of this helps keep the mud from sticking in the first place.
    You guys with the street/dual sport...this is right up your alley. Although it works for all...
  8. water racer Husqvarna
    http://www.knoxenduro.com Knoxville, Tennessee
    2013 Beta 250RR
    2009 Husqvarna WR125 1997 Fantic
    I like my bikes clean and shiney, pressure wash first tooth brush and greased lightning when needed, then spray down with maxima clear coat polish,(sc1 think). Leaves bike very shiney and helps keep mud from sticking the next time.
    Always used the Plexus on the race boat windshields, blew the water off real well better than rain-x so you could see again after getting in someones spray. now I use the plexus on my goggles, mud doesn't stick, (easy to wipe off).
    GP
  9. ozzie Husqvarna
    $h!t I forgot to mention the CT18 I use this on the motor and running gear works a treat
  10. Slowpoke Husqvarna
    Southern Ontario
    Simple green won't etch aluminum, but can stain it if you let it dry on exposed surfaces. I used to use the industrial Simple Green & it worked pretty good. Now I use the pre-soak used in touch free car washes. It works better & costs less.
  11. Suamico SD Husqvarna
    NE Wisconsin
    TXC 250
    KTM 350 , Gas Gas Raga 300
    Mr clean multiple surface cleaner for me, then maxima SC-1 to keep he dirt from sticking next time. Plus SC-1 gives your bik the new car (bike) smell.
  12. waserman Husqvarna
    Delaware,USA
    09 TE510
    BMW KTM Honda
    Simple green in a spray bottle and some type of brush, rag, or sponge and then a good spraying with mop n glow.
