Sloppy Shifter Question WR360
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by HuffieVA, Jun 30, 2010.
  1. HuffieVA Husqvarna
    Chesterfield, Virginia USA
    (2) 83 500XC's, 86 400XC, 02 WR125
    ATK, Yamaha, Kawasaki & Harley
    I have a 99 WR360 that has began to get a bit sloppy downshifting into first... sometimes you have to shift up into third and then back down to coax it into first. Started slowly but has gradually gotten a bit worse and is now starting to be a pain in the neck. Any prognosis? I'm hoping its the selector mechanism and not the shifting forks themselves... Any help would be appreciated, I'd like to track down the parts before I tear it down if at all possible.
    Thanks,
    Rodd
  2. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    Most of the shifting problems on 250/300/360 can be the centerbolt/screw in the shift drum coming loose ,if not the end of the catching mech. on the shaft can be bent,broke or just worn .A couple springs in there can also cause this.Just need to take the cover off and take a look.billf
  3. megagobby Husqvarna
    not selecting
    i can select 1st ,2nd,3rd. on my wr 250 83. but thats it................. grrrrrrrrrrrrrrrrrrrrrrrrrrr. sounds like u know what ur talking about . please can u advise me? thanks:thumbsup::thumbsup::thumbsup:
