mandolin
		I'm a brand new owner of a 2008-2009 sm 610 ie, and here's the situation: Today I went out for a ride, without checking the engine oil level.
I drove aprox 30km with a few pauses, during them the engine had time to cool some.
Suddenly, as I was riding it, the engine died on me. At least that's what I think.
Then I started to crank it up, but I heard only a click, without the starter engaging. I repeated this move 3 times, still nothing.
Then the power went out, the instrument cluster had no activity, it showed me only a blue surface.
When I put it on contact, I didn't hear that "preparing" noise what you hear before the engine cranks up.
The I realised that engine oil is leaking from the right sided engine cover gasket (as you sit on the bike).
I pushed it home, I bleeded the engine oil, and I collected a quantity of only 0.3l, plus what I lost on the road while pushing it home.
As i saw it, the oil didn't look burned, it had the usual colour of red-orange-brown.
I noticed that the engine wasn't hot or overheated, the coolant wasn't hot, but warm, the radiator as well.
I paniced, so I filled it up with oil, but there was no change, it still didn't start.
Tomorrow I will try to crank the engine manually with a wrench by the flywheel, after I open up the side cover, only tu rule out the possibility of engine scuffing/jam.
1. Is there a sensor/switch which turns off the engine if the oil pressure/oil level is too low in order to prevent further damage?
2. Did I scuff/jam my engine?
3. How much oil does it require without filter change?
4. If it's not scuffed/jammed, then why do I have leaks in he cover gasket and why do I get a blue display when I want to start it up?
Help wanted! Any sugestions? Pls tell me it's not s cuffle****************************************!!
