I have a 06 model stock and my top speed is almost 160 Khm.my friends xtx660 have top speed 175-180.why so much difference from a bike with less hp and more kg?
Sounds like you might need a bit of a tune up. In stock form mine was capable of a about 106 mph and with a free flowing exhaust and a bit of carb work could top 110 without breaking a sweat.
My 630SMS with stock 15/38 gearing pegs the revs at 110 mph. It would do more with a smaller rear, but I'm not going that way....
I got a 105 to 110 out of mine but never did it for long. I did not want a piston implant in me nether regions.
My 07 SM has seen 122mph a couple of times. Prolly could have gotten 124-128 with better fuel and a fresh tune up. Stock gearing.
What tires sizes, and was that with the stock dash or GPS? I ask because the stock 610 dash was way off on a couple I have seen. My 630 dash matches GPS speeds within a couple mph all the way up to 110.
103mph the other day with my TE with just arrows and arrow ecu no other mods (my speedo is within 1mph gps)
My 2009 Stock standard TE 610 Did 150 0n gps last weekend with panniers and camping gear gearing 15/47. at 7,000 rpm.
Just over 160 kmh is about my limit (630SM), as my arms fall off after a while (mind you, that´s only when the steering´s not on its "wobble" day). I do 150 kmh regularly on longer stretches of Autobahn on my way to work. If I had a fairing, I´d almost certainly be able to do quite a bit more. My speedo has still got 165 kmh registered as max. (done some time back).
