SM 630 antifreeze
Discussion in '610/630' started by BigT, Dec 5, 2011.
  1. BigT Husqvarna
    Looking for a good top up antifreeze for the SM 630. Can not find the Castrol blue antifreeze that comes from the factory.Are most motorcycle Silicates free antifreeze brands ok to use.
  2. EricV Husqvarna
    To be honest I don't know enough about AF to answer well, but what I did was use a little BMW OEM antifreeze in mine (had some laying around, it's blue, and figured what the hey, it's only a little.) It's a little pricey and it's of course available at any BMW dealership.
  3. RDTCU Husqvarna
    '11 630SMS
    I had to drain mine at one point, so I dumped it and went with the Yamaha green aluminum-safe stuff.
  4. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    I used the blue Honda auto anti-freeze as it is the specified ethelyne-glycol type since I couldn't fine any Castrol, anywhere! Hope it is OK!
  5. strongleftleg Husqvarna
    Canada
    In the future if your only topping up a small amount skip the antifreeze and just add distilled water. Unless your bike is in really cold weather.
    On all my bikes I mix automotive antifreeze with distilled water 50-50. Almost all modern antifreeze's are compatible with each other and with all kinds of metals.
