How much difference would there be running a tube in a tubeless tire as oppossed to running a tubeless tire? ( this would be on a 2009 SM610 )
I'm not sure I understand the original question. If you have a 2009 SM610 with unmodified stock wheels, you are better off running a tube whether the tire is tubeless or not. :-) There are products/methods to cover over the spoke holes for converting to tubeless but not many people go to the bother with that on a 610.
Sorry , Is there any performance differences when you are running a Tube in a Tubeless tire? As opposed to running a Tube in a Tube tire?
weight is the biggest difference I suspect. Tubes are rotating, un-sprung mass so keeping that to a minimum is a huge benefit but the reality is that probably 90% of supermoto riders run tubes.
I guess it depends more on what specific tires you're talking about rather than if you use a tube or not. Most SM bikes use tubes with tubeless tires. Not for performance reasons, just because most wheels need tubes and most sportbike tires are tubeless. At least that's my understanding after having a SM for a couple/few years. What tube type tire are you considering using?
Jimmy, if you feel like doing away with the tubes altogether you can try this; http://cyb.smugmug.com/gallery/7250813_ZxQA5#465979444_cW2xa http://www.supermotojunkie.com/show...s-for-under-10.00 &highlight=Tubeless for $10
