sm610 ie steady idle?
Discussion in '610/630' started by MotAd, Nov 16, 2011.
  1. MotAd Husqvarna
    London
    SM701
    2009 Triumph Daytona 675
    have done a search for this but couldn't find an answer. my idle fluctuates between 1600 and 1700. this isn't really a problem but is this normal or are they supposed to hold their idle rpm? it's got all the stock nonsense on there at the mo - o2 sensor, cat...
    it's only got about 3500 miles on it so would be well early for coils although i have noticed a little rust on the coil mount which may indicate corrosion somewhere else round there...
  2. nickterc Husqvarna
    TE 610ie
    Mine does the same.A little up and down is normal...
  3. MotAd Husqvarna
    London
    SM701
    ah cheers fella :)
  4. Muddy Waters Husqvarna
    On the islands
    Mine (08) idle steady at 1500 RPM
  5. MotAd Husqvarna
    London
    SM701
    thanks for the feedback mate. i suspect when i get my full system and the plug for the o2 sensor it should settle it down. we'll see
  6. Tim Rabe Husqvarna
    NW New Jersey
    2006 SM610
    Mine fluxtuates between 1500 and 1600 after the X3 slip on and O2 sensor removed.
