Hiya I've an 09 SM 610 Injection bike. Recently added the power up kit from Husky (Lambda plugs etc) It has a Leo Vince Can too. The bike now idles a little higher than usual (about 2000rpm) and I've read others have adjusted the idle back down to around 1600. My dumb question is this... Where do I find the Idle adjustment screw or cable ? The manual states the adjustment position for a carbed model but I wonder if its different on the IE bikes. Also from my test ride after fitting the kit .... Well all I can say is "WOW" What a difference it makes! The bike feels a lot more responsive. HuskySport advised that I should pop the bike into them so they can run some diags on the bike with the kit on (guessing they adjust the fueling a little bit with Ibeat) Is it ok to keep the kit on without the adjustments or in your experience would you get this done too ? Thanks for reading and hope you have the answers I'm looking for. TFN Gav
Above the rear brake fluid can, behind the air filter box...little screw with a spring behind it...kinda hard to get to...do you see it?
Heya Muddy Thanks very much for the reply, I'll take a look as soon as I get home from work tonight. Also do you know If I 'need' to get my bike remapped with Ibeat ? Thanks very much Gav
