Smr 510 Rear Fender Part Number
Discussion in '4 Stroke' started by MuskyHusky, Mar 23, 2019.
  1. MuskyHusky Husqvarna
    nc
    2012 cr144 1983 wr250
    maicos
    Hey I have a 2009 smr 510 and was wanting the all white fender with the tail light cavity built into it like the one in this picture but I’ve searched everywhere for a part number and can’t find one I’ve called halls they didn’t know either. Anybody got a clue? I’ve been trying to find this fender for over a year now lol
  2. Caiman Senior Vice Procrastinator
    Australia
    SWM SM500R
    1. Might be 8000H1705, (don't hold me to it though!) that's off the 2010 SMR and 2016 SWM SM500...
  3. MuskyHusky Husqvarna
    nc
    maicos
    Thanks I guess I’ll give that a try if no one else knows the answer. That does look like a different part number from what I usually see could be it but the only swm models I could find that use that fender are the 2016 enduro models the sm seems to use the black drop down one, do you know if there’s anywhere in the us to order swm parts?
  4. MuskyHusky Husqvarna
    nc
    maicos
    Ok I went ahead and bought a tail light off eBay so I didn’t have to wait for one from swm part number is 8000H1418 same part number as swm so I’m guessing it’s the right light. Someone messaged with with the 2010-2014 te 250 310 rear fender part number being 80b0h1404 and I’ve found that same part number listed for some 510s so I guess I’m going to give that a shot first unless someone tells me differently beforehand. I’ll post an update and pictures when I get the parts
    DCrider likes this.
  5. MuskyHusky Husqvarna
    nc
    maicos
    Hey you wouldn’t happen to know if these side panels will fit my bike and if they are available for purchase anywhere would you? I mean I know you have to switch to a swm seat to use their plastics just didn’t know if this particular set would work
  6. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    The bolt holes look the same. I would think that all the holes in the frame and subframe would be the same since they are using everything from husky. One would hope. Those side panels are pretty sweet.
  7. Caiman Senior Vice Procrastinator
    Australia
    SWM SM500R
    The plastics will bolt up, it's common for SWM folk to fit husky seat and plastics so they can use a Safari tank on the RS500. As mentioned a new seat will be required. You'll need a whole set of side plastics (radiator shroud, tank bit, exhaust covery bit) since the join lines are different to the Husky's. The 2019 SWM's use different plastics and seat to both the 2016 SWM's and Huskys.
  8. MuskyHusky Husqvarna
    nc
    maicos
    Yep those are the right part numbers obviously doesn’t wrap around the frame on the right side for the dual exhaust on the 09 but otherwise the same. thanks for everyone’s help B2A9E0D5-2F45-420F-9D3D-7B06B3B7A638.jpeg 4ADBCCFA-5471-44FA-93F6-40F5638C30B8.jpeg 6EEC724E-2862-4BA6-8455-7C6067DF7471.jpeg
    268fords likes this.
  9. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
