SMR511 coolant drain threads stripped
Discussion in '4 Stroke' started by DrRobotenstein, Nov 6, 2016.
  1. DrRobotenstein Husqvarna
    Kitchener, Ontario, Canada
    2011 SMR511
    The threads on the coolant drain hole on my SMR511 are stripped. Can anyone suggest a fix? Can a helicoil work? Would I need to get a new water pump cover?
  2. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    Helicoil. Or drill out and tap to next bigger size and match to a bigger bolt.
    Careful not to let the swarf into the motor and cooling system.
  3. DrRobotenstein Husqvarna
    2011 SMR511
    Cool. Thanks duggoey.
  4. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    give us a picture of the damage. It may be possible to chase or re-tap the threads and put the drain bolt back in (lightly) with some goop or Loctite.
    you also might consider J-B Weld or that Loctite thread repair epoxy. It should be able to handle the heat without a problem. ...and if any of these techniques fail, you can resort to a heli-coil (although I like timeserts better).
    Also, consider using an aluminum bolt for the drain: easier on the female threads and it should grow/contract closer to the same rate as the hole. Watch for galling though- go easy.
    It just a plug basically; shouldn't be under *too* much stress or pressure (20-30 psi).
    good luck.
  5. hhdwtmtw He who dies with the most toys wins...
    Melbourne, Australia
    '14 TE300, '11 TE449, '10 TE250
    Royal Enfield Continental GT 650
    If you use a helicoil kit, make sure to cover the tap threads in grease and clean/replace the grease every turn or so of the tap. The grease will hold on to the swarf and stop it going into the engine. Then use a cotton swab to clean it out at the end.
  6. DrRobotenstein Husqvarna
    2011 SMR511
    So, took a while for me to get to doing the fix. But it was actually super easy to just take the pump cover off so I could drill/tap for the repair.
    Trenchcoat85 likes this.
