sms 630 suspension Settings
Discussion in '610/630' started by julienl, May 29, 2018.
  1. julienl Husqvarna
    paris france
    501 FE 2015 My NEW
    XT 500 1980/630 SMS 2011(sold out)
    Hello, im shearching but i have not find ;( .
    Please Have you tips for the settings of my REar suspension on my sms 630 2011.
    and after Front. I feel my bike is soft, i want more strong.
    I'm 75KG and i ride mots of cityroad.
    Thanks
  2. Rotax_655 Husqvarna
    If I can around the world
    ex TE 630
    Aprilia Pegaso 650 GA
    what kind of oil do you have in the forks?
    you could use a denser one like a sae15
    always of good quality with a high viscosity index
    alternatively you can replace the springs with others that have a harder constant
    now you should have one as standard
    k = 5.4 N / mm
  3. julienl Husqvarna
    paris france
    501 FE 2015 My NEW
    I m schearching about number of click on rear suspension.
    I have find 20 for the rebound setting in the down of suspension but i dont have the higher settings
  4. Rotax_655 Husqvarna
    ex TE 630
  5. julienl Husqvarna
    paris france
    501 FE 2015 My NEW
    thanks rotax, i dont find the number click on picture 2, what means about "Register 1 and register 2" ? All open ???
    open is strong or is soft ?
  6. Rotax_655 Husqvarna
    ex TE 630
    The registers 1 and 2 placed in the "all open" position (unscrewing anticlockwise) give the factory "standard" regulation.
    The more you close the registers 1 and 2 and the more the damper hardens the compression of the hydraulic part (at low and high speed)
    Low internal small screw speed (number 1)
    High speed external large ring (number 2)
    Personally I keep them at half of the total stroke both the screw number 1 and the dial number 2
    So if, for example, you count 20 clicks in total, put it at 10 clicks
    I hope the translation is correct
  7. julienl Husqvarna
    paris france
    501 FE 2015 My NEW
    Excellent!! Thanks Rotax.
    And for the lower setting, wath do you have?
