Snap, Crackle, Pop....
Discussion in 'General (Main)' started by okiehusky, Jan 13, 2014.
  1. okiehusky Husqvarna
    sand springs, ok
    2012 TXC310
    '04 KDX200, '03 KX125, '75 Hercules
    Had a bizaar episode with my '12 TXC310 yesterday. Background: It's been cold here for weeks, but the bike is in a heated garage and has been started every week. No problens. Yesterday I started the thing per usual ritual, it idled fine for a couple of seconds (never touched the throttle). Then it began to pop and hiccup, then finally died. I stabbed the starter again and snap, crackle, pop. Never did refire. I haven't taken a deep dive into it yet due to lack of time. But, I've got to admit I'm totally bewildered. The possible scenerios for this are almost limitless, but I'm all ears regardless, if anybody wants to chime in or give their nickel's worth.
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    bad gas? its been sitting? fuel is terrible now, goes all to hell in record time.
  3. Micfasto Husqvarna
    2012 TXC 310
    XR400, Vstrom
    Check your battery terminals to see if they are loose.
  4. okiehusky Husqvarna
    sand springs, ok
    2012 TXC310
    Shouldn't be bad gas. It's started weekly and kept in a heated garage. As a matter of fact I used some of the same gas from the can, poured in a little BELRAY MC1, and took my KDX out in the woods. Ran like a champ. Battery terminals are good. No problem with cranking power either. The EFI whirs llike it should and the motor turns over strong. Just no fire. Unless you count the occasional pop. Quite dumbfounded, me is.
  5. robertaccio Husqvarna
    San Diego, Ca
    so ya got fuel, did you verify that the nazzle sprays?? so ya got compression? you need ignition, start from the plug and go back plug cap, wire, coil, Ignition unit (ECU?).
  6. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I ran some race gas for a while in mine that had ethanol in it. I had the tank off doing some other work and when I pulled the fuel line I noticed little goo balls in the line. When I buttoned everything back up I ran some SeaFoam through it and it cleaned everything up. I dump a little fuel stablizer and 2-stroke oil into every can of gas now and no further problems (knock on wood).
    robertaccio likes this.
  7. okiehusky Husqvarna
    sand springs, ok
    2012 TXC310
    Enough spark at the cap to make you wet your britches! So, I thought, what the hell. Maybe it fouled a plug. Which would be a first for me and this 4 stroke. After performing several Houdiniesqe contortions the new plug was in. M*ther F*cker ! The thing fired right up. A freeking fouled spark plug. Go figure. Let me apply the Dumbass Ointment myself please.
