Some Husky Rally pron by Simon Pavey
Discussion in 'Racing' started by Ruffus, Oct 23, 2012.
  1. Ruffus Husqvarna
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
  3. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    That's one way to carry more fuel! The whole back-end appears to be a fuel cell!
  4. twmtatenrost Husqvarna
    Is the 449 a stock bike with Dakar bodywork , tanks etc or a full on factory based M/c. I used to have one and went to a 310. both great bikes only bad thing was 449=heavy for wet welsh enduros and the 310= wont start ! and unreliable.
    what do you think Simon?
  5. ray_ray Mini-Sponsor
    The Philippines
    Not sure on the bike and nothing official but that frame \ SA might be ~unique ... It looks like the Husky frame but the bike has the linkage sitting under the SA when the usa released models have the linkage on top of the SA ...
    EDIt: Not sure if that frame mimics the Husky frame or not ..
    That bike also has WP forks where the released 449s had KYBs(?) ... I'd guess ... it ain't a stocker ...
  6. DG Harv Serv Husqvarna
    UK
    Ohlins Forks and Rear Shock .
  7. Ex HVUK Husqvarna
    England
    None
    It is a standard 2012 TE449 with the linkage on top of swing arm but with Ohlins forks and shock fitted instead of the KYBs. The kit to transform the bike to 'rallye spec' is complete bolt on, no welding needed at all so the bike can be converted back to standard if required. It carries 25l of fuel which in testing has given over 300 miles range.
    More info on www.simonpavey.com
    Dave
    Tinken likes this.
  8. ray_ray Mini-Sponsor
    The Philippines
    I was referring to the bike ridden by the speedbrain team ...
    Thanks for the 'rallye spec' clarification ...
  9. Ex HVUK Husqvarna
    England
    None
    Ah yes Speedbrain bikes are indeed very different. They are still using the G450X developed chassis without the lower frame rails of the 449 and as you spotted their own linkage under the swing arm.
    Dave
  10. ray_ray Mini-Sponsor
    The Philippines
    Interesting and thanks for the details ...
    Does or will the speedteam share what they might be doing to the internals of the engine? Their riders keep saying the engine is doing very well for them this year ...
  11. Ex HVUK Husqvarna
    England
    None
    Currently have no confirmed info but I did hear they were using the Husqvarna version of the engine now rather than the BMW version (hydraulic clutch and six speed gearbox).
    There is due to be a pre Dakar press conference at the factory so there may be more info available then.
    Dave
  12. ray_ray Mini-Sponsor
    The Philippines
    Getting to be a real crossbreed machine for that team .... And stepping off the bmw engine to the Husky bred horses? Sweet!
    Why not use the KYB forks that come with the bike instead of the Ohlins? Just can't get the performance you want from the KYBs at the speeds you are traveling at?
  13. Ex HVUK Husqvarna
    England
    None
    Ohlins is listed as one of Simons team sponsors so I assume he's not only getting product but technical support from them too which is almost as important as the product itself. Next time I speak to him I'll ask if he had any issues with the KYBs - he's not mentioned it before so it's more than likely a result of sponsorship. To clarify, although Husqvarna via us as HVUK is sponsoring the team, the development is all being done by Simon and his team down in Wales.
    Dave
  14. ray_ray Mini-Sponsor
    The Philippines
    That makes sense ... sitting here on the couch its easy to see this all as racing but the business side that must be there for all this to happen, is sometimes out of scope ...
    Seeing the videos of how fast these guy are going over the dunes and roads, trails ESP, they gotta have a a good suspension that is well beyond anything we might need ...
