It seems a number of people are having issues with tuning the Power Commander and the Autotune add-on for cruise/part throttle.
In the interest of seeing people spend less time and money on tuning, and more time riding, here's my take:
The Power Commander can give you good results for 3/4 to full throttle but is going to be frustrating/inconsistent for part throttle.
The factory Husky fuel injection uses a manifold pressure sensor (MAP), throttle position sensor (TPS), coolant temp sensor, air temp sensor, and RPM to calculate fueling (known as speed density). The Power Commander overlays this stock fuel map with one that uses only the TPS signal and RPM (known as alpha-n).
Using a MAP sensor (speed density) is a much more accurate way of tuning fuel injection because it takes into account engine load by using the MAP sensor signal, along with the throttle position. Alpha N systems are really only accurate at idle and large throttle opening, everything in-between, like part throttle, is a guess at what engine load really is. For a given throttle position, load can change due to what gear you're in or whether you're going up/downhill.
Some fuel injection systems transition from speed density to alpha-n after a certain load/throttle position. Not sure if the Husky system does this, it may though. This is because the engineers know the alpha-n system can be accurate/useful at large throttle positions, but not-so-much at part throttle.
The autotune add-on attempts to counteract the fact that alpha-n isn't accurate at part throttle, but this introduces an issue for us single cylinder folks. The exhaust pulses from a single cylinder can provide inaccurate wideband 02 readings at idle/low rpm and part throttle. At low RPM there's gaps between the exhaust pulses coming from the engine and the sensor expects a constant exhaust flow (fairly constant atleast). Part throttle situations also dont have alot of exhaust flow, and when combined with gaps between pulses at low rpm you get a signal that may not be accurate. Try taking a wideband reading at idle with a high sample rate and you'll see what I mean.
As mentioned, the alpha-n system works well at/near WOT. And at higher RPM and higher engine loads, the wideband signal becomes much more accurate/reliable. If you're tuning for that situation then the Power Commander will work as promised, but for part throttle/midrange on single cylinder bikes you're likely to have a tough time.
Disclaimer: I've got some experience with standalone FI systems for cars (both speed density and alpha-n) and have tuned single cylinder go-kart engines in the past. Both are hobbies. Just wanting to share some things I've learned along the way.
