Someone educate me on carb please
Discussion in 'EFI/carb' started by Blackbeard, Oct 12, 2016.
  1. Blackbeard Husqvarna
    Te450
    I have a 05 450 te with the fcr, last night I pulled it off to adjust the float height and install my fuel screw. Bike fires right up. Gets 50mpg and runs great but from what I'm seeing it seems like I have big jets in it? Currently I have a 180 main 45 pilot, and what is the third jet behind the main? Mine was either a 8.5 or 85
  2. Up-tite Husqvarna
    Called a Start Jet, when choke is pulled this is where the fuel comes from, we call it a choke but it is not really it's an enriching circuit.
    Later George
    Blackbeard and robertaccio like this.
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
  4. Blackbeard Husqvarna
    Te450
    So George would you say my jetting specs are pretty good? I'm in so cal and bike runs great. I just wasn't sure if the 40 pilot sounded a bit lean. But I get great mileage and smooth power so I wanted to leave it as is. Whoever owned this bike previous was a huge fan of yours as it has probably most products you ever made on it. Axle bolt, exhaust guards ect
  5. Up-tite Husqvarna
  6. Blackbeard Husqvarna
    Te450
    Was there supposed to be text? I see your quote but no response! Lol
  7. Up-tite Husqvarna
    Jetting sounds fine 45 to 50 on the pilot, main is good.
    It it runs good just run it.
    Later George
  8. Blackbeard Husqvarna
    Te450
    Thank you, it has a very slight pop on deceleration but only sometimes and when it does it's very slight. The fuel screw was 1.5 out maybe I'll try 2 out to RI JEN it up
