250-500cc spark plug for WR300
Discussion in '2 Stroke' started by BikeSDP, Jul 16, 2009.
  1. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    I feel a little stupid for posting this, but just picked up a '09 300 today and am giving everything an inspection. When I pulled the plug wire, I found there was no terminal cap (or whatever it's called) on the plug. Is this the way it's supposed to be? It sure doesn't look like it's stuck in the boot (as far as I can tell). So does the boot just go straight on the threaded portion? :excuseme:
  2. Rusty 2 Husqvarna
    Ashland, KY
    Yes, the boot will only fit over the threaded stem. You have to remove the screw on tip from a new plug when you install one.
  3. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    Cheers for the quick reply...
  4. burstcasino Husqvarna
    Austin, TX
    2012 Husqvarna WR300
    2001 KTM 520 exc
    I have to admit I'm scratching my head on this one with my 12 wr300. Looking into the open end of the spark plug boot looks like a spark plug terminal cap is stuck in the boot. The spark plug has only the threaded post with no cap. If I twist the plug into the cap in the boot it will start to thread, but that's problematic when trying to install the plug into the jug. Part of me wants to take some needle nose pliers and pull out the cap from the boot, but not knowing if that's "standard" I don't want to break it but seems kind of a weak link to me.
  5. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    The bare threaded part can get bent sort of easily. I have thought about getting a different style of cap that takes the little thread cover installed on the plug.
  6. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I don't care for those either. I switch them over to a NGK cap that uses the terminal. They have a nice tight "click" when they go on.
    burstcasino likes this.
  7. burstcasino Husqvarna
    Austin, TX
    2001 KTM 520 exc
  8. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Red TB05EM
    burstcasino and Dirtdame like this.
  9. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    On the plug pic you posted, notice the "P" type plug on the left. Those run better in 2-strokes than the regular non projected nose plugs. In my KX500 I could get those to last a whole season or more. Cam.
  10. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    "P" series plugs run hotter at lower rpm than a regular plug. That's why they work so well in 500cc bikes.
  11. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Yes, they also run them in trials bikes.:)
  12. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Yes, they do.
  13. Rob578 Husqvarna
    Atlanta GA was CA
    Beta 300RR Beta 500RS TE 630
    Honda 919 sold FJR1300 sold
    Where did you source it?
  14. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    Dennis Kirk sells them.
  15. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Yes, that's where.
  16. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    I picked one up from my local Yamaha/KTM dealer.:banana:
  17. burstcasino Husqvarna
    Austin, TX
    2001 KTM 520 exc
