Speed wobble
Discussion in 'General (Main)' started by MuddyWaters, Dec 3, 2013.
  1. MuddyWaters Husqvarna
    Marin Co. California
    2013 TE310
    suzuki drz 250
    I am a new Huski rider. I have a new 2013 TE 310. I have just had a shoulder surgery so i haven't the upper boy strength to ride the dirt yet but have been riding the street some. I have noticed that after 45 mph the bike for lack of e better explanation feels like it has a controlled speed wobble. Is this the stalk tire?? Is it set up wrong. Any ideas??
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    The stock tires are not very good, but the wobble may be from something as simple as race sag. Proper suspension setup will eliminate many rider woes such as speed wobble.
  3. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Is this a side to side wobble ? or does it just seem to sort of feel like it has a sort of shake? I had a front wheel that gave a shake / wobble so popped in a lighter smaller type of rim lock and it vanished.
    Strangly this wheel the rim lock was close to the valve but my other wheel that did not shake the valve and rim lock are drilled as opposites.
    If all the wheel bearings and headstock bearings are good this is most likely to be the cause.
    MuddyWaters likes this.
  4. ghte Husqvarna
    Bright, Victoria Australia
    If this is on hard top it might be an out of balance wheel. Most front wheels have rim locks on and that is fine in the dirt. However a counter balance on the opposite side to the rim lock is preferable for frequent road riding.
    May also consider dropping the front forks down a notch in the clamps. That will put a tad more weight on the front and has been known to cure matters (will also improve steering response time marginally)
  5. organ donor Husqvarna
    Berlin
    Got rid of my wobble (630SM) .... eventually, by having the wheels carefully balanced. Has to be done again after a while or the wobble returns.
  6. AgedFlatulence Husqvarna
    Little 'ol Lady Town, CA
    MY2013 TE449, 2015 FZ-07
    Does the TE310 have the same *(&* Michelin front tire as the TE449? I never knew how bad that tire was until Ty put the Goldentyre on the front of mine. All that high speed wobble simply went away. That Michelin grabbed every line, crack and pebble that caused me to keep both hands on the bars at all times at speed. The Goldentyre goes where you point it with zero issues.
  7. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    first step balance and proper sag then go from there. tire choice, bearings, all the other bits
  8. MuddyWaters Husqvarna
    2013 TE310
    suzuki drz 250
    You sound like your having the same trouble. I dont store it here so i cant look but yes this thing grabs every little line in the road I'll take the time here as well to thank every one that responded. I think a new tire might be the way to go with some balance. I dont really plan on riding the road much. Thank Aged :)
