Speedo boots then dies
Discussion in 'EFI/carb' started by dsezgen, Nov 10, 2015.
  1. dsezgen Husqvarna
    2009 SMR 510
    Has anyone ever seen this issue?
    I have a 2009 SMR510 that had water in the speedo. I took it apart, dried it out, then re-installed the speedo. Now the speedo powers up, goes through its boot cycle then goes dark after the ignition is turned on and left on. The only difference that I can tell is there is a "2.2" displayed before the normal power up cycle. I don't recall seeing the "2.2" previously either, does anyone know what that means or where I can find more info?
    I have a video I can send if that helps.
    Thank you!
