My speedo quit working. Magnet is still there and sensor still in place. I have service manual but can't find anything on it. 09 610 anybody have this before ?
http://www.cafehusky.com/threads/te610-speedo-quit-odometer-still-works.23001/ maybe you have a broken wire
My speedo is giving wild readings, ODO still works, tried disconnecting the battery, didnt help. I recently changed my headlight (Trail Tech X2 HID) and have an off switch so the dipped beam can be switched off. I also have an LED rear tail/stop light. I have been running with the headlight switched off, so theres little current draw from the battery. I have done some googling and it seems that the dash might not like high volts. The speedo usually starts playing up a few miles into a ride, which could be as the battery passes a certain voltage, possible overcharge? I will try running with the dipped beam on to load the system to see if it will stop the speedo problem.
