Speedo/Rev Counter
Discussion in '4 Stroke' started by Mercury264, Oct 21, 2008.
  1. Mercury264 Husqvarna
    Metrowest, MA
    Is there any way to power up the speedo/rev counter WITHOUT having the engine running ? '06 TE 450 if it matters.
    What genius thought that one up :banghead:
  2. Coffee CH Owner
    Stock - no.
    The schematic shows power to it I believe so there must be another wire/signal that is keeping the display off.
    The bike would need an on/off switch or the battery would die. Suppose the one on the handle bars could have been used... not sure why they didn't do that - maybe they were worried people would leave the switch in the on position, that is what I do.
  3. Mercury264 Husqvarna
    Metrowest, MA
    I figured that would be the answer but I thought I'd ask anyway.
    It seems a silly design to me - as you say, there is an on/off switch so why not use that to power up the display and have something like a timer or something to turn the display off if you leave the switch on. Does the speedo contain a battery to keep it's setting (clock etc.) or does it use the main bike battery ?
    Just seem a bizarre way to do it.
  4. tadgh Husqvarna
    what do you need the rev counter for if the bikes not running?
  5. Mercury264 Husqvarna
    Metrowest, MA
    Not sure if that was a genuine question or not....I will assume yes so here goes :D
    It's all one unit, it's silly to have to turn the engine on simply to, say, read the odo or set the clock. Very silly indeed.
  6. Hoder Husqvarna
    Buckley, WA
    On the '06 610 the headlight and speedo are powered from the battery and so the engine doesn't have to be running. It's my understanding that they changed this in '07 or '08 to run off the stator. I wonder why the 450 is different from the 610? Believe me when I say I'm an electrical idiot but can you change the power source to the battery so it comes on with the key?
  7. Coffee CH Owner
    On the 2006/2007 TE250/450/510 there is no key.
  8. Mercury264 Husqvarna
    Metrowest, MA
    There's no key on the bike but there is a power switch.
  9. Coffee CH Owner
    Actually if you look at the schematic the big red button on the handle bars is either open, or it grounds a lead to the electronic box... so it is not a power switch.
    They easily could have made it a power switch too though but that would be more wires.
  10. tadgh Husqvarna
    yeah it was a genuine question :) sorry its just on mine the time stays set even after its switched off so i dont need to reset it again..but then again the only thing that i consider the oem unit is good for is an hour meter for servicing and the max speed readout for bragging rights :thumbsup:
    you might notice if you push down the kickstarter (with the decompressor pulled) the display lights up for about 10 seconds ..enough to read the odometer maybe ?
  11. Mercury264 Husqvarna
    Metrowest, MA
    interesting, I never knew that.
  12. Mercury264 Husqvarna
    Metrowest, MA
    No worries.
    I had seen the kicker thing. It just seems a really really stupid thing to do when you have a battery on the bike (I could see it on non-battery bike maybe and even then, you could incorporate a battery in the unit itself) to not have the display show when the bike is not running.
  13. WSA Husqvarna
    Reno, NV
    FYI, the Euro3 versions that have the keyed ignition powers on the speedo with the key turn... along with the hour meter. I've left my key on a few times and now have many more hours on the meter than actual... urrrg.
