Speedo wires - broken
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by AUSKY, Mar 11, 2009.
  1. AUSKY Husqvarna
    Cairns, FNQ,Australia
    08 TE510 96 WR125 00 WR360 13 WR165
    1999 XR250 83 YZ 490
    I recently broke the wires from the speedo sensor, that curves around & follows the brake line, at the connector near the dash & I can't tell which wire is which as they are the same length & have been repaired before with heatshrink.
    Does anybody know if the "polarity" of the sensor wires create any problems if it is connected incorrectly?:confused:
  2. Swampds Husqvarna
    Sarasota Florida
    I had the same thing happen to mine. The speedo seems to work with the wires either way.
    I am interested if someone knows anything that we don't....
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Me too, fixed it and went on.
  4. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    no polarity issues
    the magnet and sensor is an open/closed switch really
    with every rotation of the magnet to the sensor it is as though the two wires are being touched together- creating continuity for that moment, every pulse of continuity is delivered to the speedo generating "speed"
    so if you sat there and touched the two wires together you could see how fast you could go- :lol:
