sprag clutch part numbers...
Discussion in '4 Stroke' started by aethelred, Mar 31, 2014.
  1. aethelred Husqvarna
    UK
    I have heard that a sprang clutch from a KTM Lc4, Ducati monster or even the rotax are all the same!
    I have the complete assembly for my TXC 310 ready to go in under warranty.
    What I want to do is just get hold of this part number that fits. I think they be all the same. I can then replace this part before any damage is done to flywheel...:)
    Can anybody help me?
  2. joedirt Husqvarna
    PA
    wr250
    I used one from a 2005 honda crf250x
    R_Little likes this.
  3. R_Little Husqvarna
    NJ
    Mine siezed up solid and I can't seem to get it apart.
    I had some spares from an old motor so I swapped them in.
    I think the sprag spins on the starter gear and is fixed on the flywheel so it sould not wreck the flywheel......the starter gear is anothr story.
    I did not know the parts are the same on an LC4!
  4. aethelred Husqvarna
    UK
    My new Sprag Clutch...
  5. aethelred Husqvarna
    UK
    Some pictures showing condition of parts...
    I have a collection:-
    Michael Collins likes this.
  6. aethelred Husqvarna
    UK
    New sprag clutch seems to be OK. No noises yet.
    What are the issues with the starter gear then?
    Nice weather Sunday...
  7. R_Little Husqvarna
    NJ
    Wow,
    I'm sure mine looks like that too.....if I can ever get it apart! Did yours come apart?
    The ring gear is toast
    The flywheel too it loooks like.
    Did you replace it all?
    Can you buy a flywheel seperately, or does it come with a stator?
  8. joedirt Husqvarna
    PA
    wr250
    newer bikes list the stator and flywheel part #s seperate
  9. aethelred Husqvarna
    UK
    Mine just didn't grip. The starter just span. Some do lock up!
    Just replaced the sprag clutch only. Seems to work fine even with the rubbing marks...
    Trick is to replace sprang as soon as it gets noisy. Don't wait till it takes out the mateing parts...:)
    £300 for flywheel/ magnets here in UK. Not sure if that comes with Stator?
  10. icyhusky Husqvarna
    Montreal, Canada
    2010 TE250
    Ducati 900ss sp (sold)
    Hi guys have you confirmed the ktm lc4 uses the same sprag as part husky #8000 87289?
    I am getting ridiculous delivery times for the part...
  11. tjf Husqvarna
    2013 txc 310
    gasgas txt pro 290
    What was your issue here? Have you had the same problem I am having - shearing keys? I have sheared 2 in the last week and am not sure what to do. I almost think the taper of the shaft is not doing it's job of holding the flywheel. Have you experienced this? Got any advice for me as to how to prevent shearing keys? My bike is a 2013 txc310r. I have less than an hour of riding time on it and have sheared 2 keys!
  12. joedirt Husqvarna
    PA
    wr250
    Are you sure you're putting it together right and torquing the nut properly? Can you post some pics of the parts just to get idea of what might be wrong? I've had 4 of these bike and no problems with shearing keys.
  13. icyhusky Husqvarna
    Montreal, Canada
    2010 TE250
    As soon as i disassemble the flywheel i will be posting pics and reporting on condition of the woodruff key and existing parts. Got my puller from ebay at 50$ shipping incl. Not bad.
  14. Mark Hughes Husqvarna
    2010 TE 250
    KTM EXC 2008 , Harley Custom 1200
    Mate , where do you purchase the sprag clutch part / bearing from and how much was it ? i cant get any parts at all here in Australia . cant even purchase a fly wheel puller for the thing .
  15. need2boat Husqvarna
    South Jersey
    2012 TXC310
    1993 BMW K75s
    The husky dealer near me central Jersey Cycles had 2 in stock I think the going rate is 84.0 US.
    Mark Hughes likes this.
  16. Michael Collins Husqvarna
    Newtownards {Belfast] Northern Ireland
    2013 Husqvarna 310r
    Vtx 1800 , R1 1000 , Sherco 290.
    Hi there was looking at your post very interesting to hear other makes of motorbikes have the same sprag clutch good news if you need just to buy a sprag clutch , I recently replaced my starter cog due to sheering and had to buy the sprag ,starter wheel and worm and bearings as a kit they wouldn't sell separately from husky dealers, Could you let me know where you bought your sprag clutch from if you wouldn't mind ,
    Cheers
  17. joedirt Husqvarna
    PA
    wr250
    I
    I have used one from a 2005 honda crf250x.
    Michael Collins and R_Little like this.
  18. R_Little Husqvarna
    NJ
    I've put many flywheels on with the following procedure and never had one shear a key again....yet
    Remove all burs if any are present. Put a little valve lapping compound on the flywheel and GENTLY lap it to the crank end.
    Clean it off and use a NEW woodruff key. make sure the key fits W/O binding. Lightly file off any burs.
    Put a little Loctite 609 retaining compound on the shaft end...just a little it will set in the lapping scratches you just made.
    Use the ZipTY tool to hold the flywheel in place while tightening and use a REAL Torque wrench to tighten to 80NM which is a little tighter than the spec.
    Do not just blast it on with an Air Impact Wrench. That will probably shear the key right there.
  19. hhdwtmtw He who dies with the most toys wins...
    Melbourne, Australia
    '14 TE300, '11 TE449, '10 TE250
    Royal Enfield Continental GT 650
    The sprag clutch is designed to grab the hub when the engine is stopped or turning over. Once the engine starts then centrifugal force releases the clutch from the crankshaft.
    I had the same issue with mine slipping. The cause was when the bike backfires it stretches the garter spring. The wear on the clutch surfaces looks normal. Simply go to a bearing shop and buy any oil seal for a 50mm diameter shaft. Take out the garter spring from the seal and fit it to the sprag clutch. Reassemble and ride.
  20. Michael Collins Husqvarna
    2013 Husqvarna 310r
    What's your starter motor like is it ok I had to get one because the brushes wore out they can't be replaced easily but I'm going to have a go, a new starter motor is over £200 , how many hours have you got out of your bike before you've got any trouble from your bike , I think the 310r I have is a fine looking bike very easy to ride and don't want to change it however was very close to trading it in and buy one of the newer husky's(KTM) but do not want to do that .
    Cheers
