Sprocket and Chain Recommendations - TE610
Discussion in '610/630' started by sumbike, Apr 2, 2014.
  1. sumbike Husqvarna
    Rancho Murieta, CA
    TE610
    KLR 650 Sold
    Got a pretty well stretched chain and worn sprockets after about 6K miles. Currently running 15 - 45 which seems fine overall, but wondering if dropping to 14 - 45 would make a noticeable difference when slogging off road. I'm kind of a toad so looking for slightly better low end without an adverse affect on the top end. Can anyone say whether one could tell the difference?
    Also, any recommendations for sprocket and chain sources?
    Thanks!
  2. Rockchucker22 Husqvarna
    Bishop
    Your top end speed will be reduced by about 15mph but your first gear will be much more useable in the dirt.
  3. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    15mph is a lot for one tooth drop. On my 511, one cs tooth drop is only 5mph
  4. zoomdude57 Husqvarna
    Seattle
    2009 TE610
    KTM 200XC-W
    I dropped to 14T up front and noticeable improvement off road. Didn't lose much on top but again not using this bike as an adventurer tourer. I went with an AFM sprocket in the back and a D.I.D X-Ring chain. The chain is pricey but definitely notice reduced rolling resistance.
  5. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Not sure what your budget is, but we sell the DirtTricks Ironman sprockets which are made from hardened tool steel, yet as light as aluminum. I just added a set to my race bike, they are the best we have tested so far.
    http://www.ziptyracing.com/sprockets/
  6. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
  7. sumbike Husqvarna
    Rancho Murieta, CA
    TE610
    KLR 650 Sold
    Thanks for the info and the links, very helpful!
  8. North Husqvarna
    Surrey, British Columbia, Canada
    te610
    530 ktm 1200GS
    I run 14 - 48.
  9. BiG DoM Husqvarna
    I run 14/47 and find it a great combo. The Supersprox sprockets are great and as said DID X ring (VMX or similar) is the way to go. Do not economise on this area, ever!
    Great resource for info on ratios and is Gearing Commander website - it also tells you if your proposed ratio is a possible wear negative which many do not realise.
    http://www.gearingcommander.com
  10. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    i found 14 -47 worked best for me offroad.
  11. sumbike Husqvarna
    Rancho Murieta, CA
    TE610
    KLR 650 Sold
    Finally got around to replacing the chain and sprockets. Went with a 14 tooth Ironman front and 45 tooth Sunstar rear with DID VX2 X ring chain. Nice improvement on the lower end, feels good on the upper end too. Probably dropped about 4 or 5 miles per hour, from about 70 to 65 at about 5000 rpm. Made cruising in 6th at 55 - 60 more comfortable, doesn't feel like it is lugging. I used the standard length chain, think it is 114 links. With the smaller sprocket in the front, adjustment in the future may be a bit marginal as it is already pretty far back.
  12. willie Husqvarna
    NS Canada
    TE 630
    Big fan of DirtTricks Ironman sprocket. Light and you get the durability of steel. Also big fan of WWW.gearingcommander.com . Excellent site to research gear ratios for particular bikes.
  13. 1lunger Husqvarna
    Bloomfield CT
    14 / 49 OEM front and iron man rear.
  14. Fast1 Husqvarna
    Minneapolis, MN
    If any of you guys have a relatively new OEM 42 take off rear sprocket and would like to get rid of it.. shoot me a pm.
  15. BrandonTe610 Husqvarna
    08 husqvarna te 610
    I have an 08 te 610. It has a leo Vince exhaust and command pro tuner about half way. With these I ran about 94 mph stock 15 45 sprockets. Recently went to a 14 48 tooth sprocket set and it does 98 mph with the same tuning. Alot more torque and higher top end speed. Idk how it works like that but it did. I guess the bike has a lot more power it can unlock than I thought. First gear is a little short but the torque makes up for it. I'm now thinking about a 15 or 14 / 52 tooth set but because I like torque much better than speed
  16. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    14 48 if the gearbox has remained the same is the final drive that the TE610 race bikes used in world enduro comp mid to late 90s
