Sprocket Question 73 WR250
Discussion in 'Vintage/Left Kickers' started by Gord, Aug 8, 2016.
  1. Gord Husqvarna
    New England
    I have a 1973 WR250. I'm looking for a 60 (or close) tooth rear sprocket. A gentleman at Unadilla was looking over my bike and thought my hubs weren't from a 73.
    Does anyone here know what other years are the same as my 73? I don't want to have a sprocket made up for a 73, only to find out it won't work. I went through the micro fiche files, but my computer is so old it takes forever to download, and at times just quits and won't download them at all.
    Maybe someone here has a 60 tooth they would part with. Is there a way I can measure the hub or the sprocket on the bike now to see what year it came from or to determine that it is, in fact, a 73 hub?
    Thanks for any help you folks can provide.
  2. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    Stick a photo up and some one will tell you within minutes what you need to know!
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    wow, thats a big sprocket
  4. Gord Husqvarna
    New England
    Here's a picture of the sprocket and hub. Sprocket has a 7" ID hole. The distance between centers on the bolt holes going around it are 3-3/4"+. The distance between centers of the holes directly across from each other is 7-9/16".
    This bike now has a CR transmission in it and is great for MX. I want to race some tight New England Hare Scrambles, and would rather deal with the rear sprocket than fight with the tapered countershaft sprocket. (In other words, I can't get it off. And it's only been on there since June.)
    Was hoping someone here would have a larger sprocket than this 53 tooth I have now.
  5. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    The hub pictured is the correct one for your year. In fact that exact hub was used by Husky for about ten years until they went to a wider brake shoe, but the sprocket mounting dimension remained well into the 80's.
    Next time you install a tapered shaft sprocket apply one small drop of thread lock to the tapered shaft just before sliding the sprocket on. This will enable the sprocket to pop off with a puller the next time.
  6. Gord Husqvarna
    New England
    Thanks Crash. I actually put a dab of never seize on it before tightening. I have a 10 tooth counter I wanted to try, but just can't get the other one off. Hence the need for a new or used rear sprocket. Was hoping to have it for a race this weekend.
  7. stormer254 Husqvarna
    England
    Yes!
    Put your puller on, apply a fair bit of pressure then heat sprocket with a fine flame torch so the heat is mostly hitting the sprocket, I use my oxy acetylene gear or a plumbers torch. I have used bits of scrap metal behind the sprocket to protect cases and seal from the naked flane.
  8. Crashaholic Husqvarna
  9. disonny Husqvarna
    upstate ny
    73 360 wr/rt, 75 wr250 78 cr250,
    83 wr250, 84 wr400
    Hi Gord, I'll have to look at my 75 wr. My 78 is 11 and 53. My 73 had a 10 and Stahls had to cut my sprocket off. They put a splined shaft in it.
  10. Crashaholic Husqvarna
    disonny, after the spline shaft went in your 73 did you then have a 6 speed? The reason I ask is because to my knowledge the only spline shaft for a 73 motor would have been the 6 speed trans out of the 74 250 or 400.
  11. Richard Colahan Husqvarna
    Upper Black Eddy PA
    71 250 Cross, 74 125WR, 75 250WR
    Vintage British bikes, 1969 Penton
    Gord...my sense is an 11 / 56 combination will be a very good set-up for you.
    Don't fret pulling what you have now...the Husky puller works very well.
    Make sure both jaws are pulling on multiple teeth if at all possible.
    Put wrench pressure on the bolt...a gentle bit of propane torch heat on the body of the sprocket.
    Another quick turn of the wrench and POP..it's off.
    Some like to put wrench pressure on the bolt...then a sharp rap with a hammer (NOT a sledge!!!) on the end of the bolt and POP!
    And there are many opinions regarding what to coat the taper with before assembly.
    For over 40 years I've used...nothing. Squeaky clean and dry. 50 ft lbs. Re-torque after a first ride.
    Also...I'll gladly trade you a new 11 for your 10...or anyone else reading this post. Or purchase it...
    My little 125 WR needs all the gearing help it can get...and only one rear sprocket (53 dished) was ever made for the early 125's.
    I need a 10.
  12. Gord Husqvarna
    New England
    Thanks folks for all the replies. I ended up having PBI make up a sprocket for me.
    Those are good sources for most Husky parts Crash. But none of those or others have what I needed.
    Richard, I might be interested in trading my 10 for your 11. Mine is new and has never been on a bike.
  13. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    Crash, it is a 5 speed tranny in my 73. I couldn't tell you what shaft they used. They told me they cut the taper sprocket off because it wouldn't pull off.
  14. Richard Colahan Husqvarna
    Upper Black Eddy PA
    Gord...I sent you a direct message on this...let me know...thanks!
