Will a 150 rear fit on the Strada? I'm planning to buy TKC 80's. Will the stock chain work with 15/49 combo? Thanks!
Collected a 15t and 49t today. 15t has the wrong shaft splines so put the standard back on. Fitted the rear 49t and the standard chain is too short. The paperwork supplied with the sprockets states the front is for a 2008-2012 BMW F650 GS but doesn't fit the Terra shaft. The rear is for a 1999-2007 BMW F650 GS and fits the rear perfect but the chain is too short. Anyone know which model of BMW will fit the Terra front sprocket? Cheers.
The 2009 & later G650GS. The 2007-2009 G650X bikes. The 2000-2007 F650GS (which is a 650cc single) You bought the front sprocket for the 2008-2012 F650GS (which is an 800cc twin and now called the F700GS for 2013) Dont you love BMW model naming.
Cheers for that Ogre_fl. Thought the standard chain would be ok with 2 extra teeth on the back but obviously not. New bash plate fitted perfect, bark busters and tuning plug on the way.
Discussed here already. Found easily by searching on "150". I think that one has been affirmed here and maybe another place. Searched on "49 tooth chain" for that one.
Thanks for that! I found the sprocket thread already and I've ordered a 15 front to start. I'm going to go with TKC 80's 120 front and 150 rear. My Aprilia SXV550 has a 180 rear and I can rocket through tight turns faster than on my CBR!
