Sprockets for 610 enduro
Discussion in '610/630' started by North, Sep 30, 2008.
  1. North Husqvarna
    Surrey, British Columbia, Canada
    te610
    530 ktm 1200GS
    I was just wondering who has changed their 610 enduro sprockets. And what you changed to.
    I was thinking of going to 14 by 48. I want more low end grunt for off road.
    Thanks
  2. 04asphalt Husqvarna
    SW Michigan
    :popcorn:
    I want to go up three on the rear, who makes one?
  3. Mike Kay Husqvarna
    California
    I went up 2 on the rear. Used Ironman sprockets. Bit more bottom end, and on top still plenty easy on the highway. This with the power up kit.
    Bike wheelies with ease. Out runs a builty XR650. :thumbsup:
  4. North Husqvarna
    te610
    530 ktm 1200GS
    I got a 48 rear, it's made by Mooseracing. I did have the 14 on the front, but I went back to the 15.
  5. Howard70 Husqvarna
    Belen, New Mexico
    Mike:
    Have you had any problems with the 47 T rear and the upper chain roller? I thought I remembered a post somewhere about the mount for the upper chain roller bending with rear sprockets larger than X, but I can't find the post and can't remember X?
    Thanks,
    Howard
  6. Mike Kay Husqvarna
    California
    No problemo at all.
    Stock gearing is great if you do a fair bit of asphalt, and have a corked up (stock) bike.
    If you only hit asphalt to connect the trails, or if the bike is 'opened up'
    then a 47 or 48 rear is a nice way to go.
    I use the Ironman rear and love it. Any bigger rear sprocket will most likely need another masterlink.
    When we goin riding? :)
    Your bike looks great.
  7. Howard70 Husqvarna
    Belen, New Mexico
    I hope to get out to California sometime this summer (once the semester is over) and we ought to do a trip then!
    Thanks for the comments on the bike - I'm working in the dark because I haven't seen photos of your ralley build yet!;)
    Howard
  8. palmczak Husqvarna
    Granby, CO
    I can't find the 47 T sprocket. I see a 46T. Who was the supplier of the 47T
  9. Mike Kay Husqvarna
    California
  10. ramz Husqvarna
    Salida, CO
  11. Mike Kay Husqvarna
    California
  12. +1 for AFAM / DriveSystems products. I've had exceptionally good experience with their sprockets in the past.
  13. knary Husqvarna
    PDX
    FWIW, I've gone from the stock 15-45 to 14-45 and now to 14-48. I'll probably put a 16 if I plan to put some real road miles in, but for the mixed use I just put the bike through yesterday (boulder crawling, single track, higher speed logging roads + some highway), it worked damn well.
  14. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Ive just done the 1 tooth front drop so far. Havent tried any tight trails yet, but it works nicely around town and on faster off road stuff.
  15. miketv Husqvarna
    Columbus, Ohio
    I run 14/47 for the dirt and 16/45 when I mostly road it. The lower gearing really helps in the tight stuff, gives my clutch a break. Haven't had any problems with the upper chain roller (yet).
  16. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
    I ran 15/47 for my Baja trip and liked the ratio. It give just a bit more oomph in 6th gear so that the bike doesn't feel like it's lugging.
  17. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    14/46 on knobbies and 15/45 (stock) when rollin in SM mode
  18. K7MDL Husqvarna
    Woodinville, WA
    Dirt Tricks does not make a 47T for the TE610 as you found out. So I went with their 46T and have both a 14T and 15T counter sprocket. I run 14/45 now and 70mph is about 5K RPM, a bit buzzy for a long haul.
    So 15/46 I think will be a better compromise street ratio to get the RPM well below 5K, and slap the 14T on for a bit lower than my current setup. Jumping to a 48T with a 15T up front would not have improved the 5K 70mph buzz.
    - Mike
  19. knary Husqvarna
    PDX
    I liked that as well, but found in the stuff posted over on ADV, that some better crawling ability is much appreciated.
