Four Digit
Trying to get this big motor to work....anyone out there know what the squish gap should be on this monster?
Thanks
Doug Walker
Thanks
Doug Walker
Yes, throttle wide open, piston and bore have been checked by two machinists and both say it is fine. Piston aligned correctly. Reeds look good. I'm 70 and weight 250 lbs... the kicker moves with little resistance when kicking...I was expecting more.,so squish is 1.7mm, reeds are in good condition, bore is new, piston facing toward exhaust, ring gap in bore checks out fine, piston feels tight in bore, spark plug and gaskets all sealed, thats about all i can think of.if all that checks out and your head is unmodified you should be getting around 160 psi, does it feel hard to kick over? iam 40s and weigh 180lbs and would find starting without the decomp a real effort.
Well thanks all for the help. This is definitely a head scratcher. I pride myself on not giving up on things and so I will continue my efforts on this project. I'll post when I get this thing sorted out. Thanks again
Doug Walker
Doug Walker
