Standing Setup TE630
Discussion in '610/630' started by Philthy, Jun 9, 2013.
  1. Philthy Husqvarna
    Mackay, Australia
    Yammy WR250f
    Just over 1200 k's on the bike now and so far - so good. Next thing is to get more comfortable standing on the pegs. I don't like sitting down too much on gravel or loose terrain, yet the 630 feels pretty awkward atm. At 190cm (6ft 3) I'll try putting some 30mm bar risers on first. I was also thinking about lowering the pegs a little or just swapping out the standard small pegs for something bigger. Any other thoughts out there for ergo setup ? Thanx
    KLOC likes this.
  2. johngil Husqvarna
    Reseda, CA
    I think the Fastway pegs in the low position are a big help. I don't use "risers", but the Scotts sub-mount adds quite a bit of height to the bars. I'm only 5'10" and thought the stock dimensions were pretty awful.
  3. Philthy Husqvarna
    Mackay, Australia
    Yammy WR250f
    Thanks John,
    I hadn't seen those before and look like a good option for a quality peg with some adjustability.
  4. 1lunger Husqvarna
    Bloomfield CT
    I have Pivot Pegz set in low position ( not much, but maybe 10mm lower than normal ). The best part about the Pivot Pegz are that you can roll back on them ( heel down ) and that allows your legs to stretch out. They are very wide too ( 60mm )! and 2" Roxs raisers set pretty far forward. This is my off road ride at the moment and I stand a lot. Compaired to the OEM set up, this is much better! I'm 6' 1" with long legs and long arms. You will need the Motion Pro 2" longer clutch cable with the Roxs. Hope this helps
    Philthy likes this.
  5. BaronVonDarrin Husqvarna
    Norristown
    2011 te630
    wr250r, CL175
    where do I find a longer clutch cable for the te630? the motion pro site and their cable selector did not list the te630...
  6. 1lunger Husqvarna
    Bloomfield CT
    Check with Kelly at Motosportz
  7. kirbybikes Husqvarna
  8. mekanik Husqvarna
    Kootenays, Canada
    630 is a hydraulic clutch not a cable, don't know of a longer hose yet.
