starter problems 2012 te 310
Discussion in '4 Stroke' started by nep2012, Oct 8, 2014.
  1. nep2012 Husqvarna
    2012 te 310
    read threads on starting issues. From starter gear and shaft upgrades to improper valve adjustments causing problems. this weekend I am going to check valve adjustments and then go from there. Dealer seems to think it is a starter issue but hasn't checked the valves. Starters are on back order til who knows when so I will get a rebuilt one from Bill's in Oregon. Was aslso advised to get the starter gear kit upgrade. This is if the valves are not the problem. Does anybody have any other experience with this mess.
  2. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    Yes, I have experience with this. Luckily it did not happen while riding but after an all-day ride.
    A valve adjustment and starter kit did fix my 2012 TE310. As I remember, the exhaust valve tolerance is unforgiving and must be right on or tighter than spec. That was about 2 years ago and no problems since. Bill's did the work. I would do both, ...check the valves and put in a new starter.
    Dave
    my 310... about 2,000 miles on it now
    Johnrg likes this.
  3. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
    klx 250s vulcan 900 yamaha stryker
    How many miles do you have on it , have the valves ever been adjusted?
  4. everfree Husqvarna
    Bend, Oregon
    On my bike?
    About 2k miles. I bought the bike used with over 1k miles on it, so I don't know the whole history. But since I have had it, the valves have been adjusted once.
    Also, I am running 0-40w Mobil 1 and a stainless oil filter. Love the bike.
    richard kersten likes this.
  5. nep2012 Husqvarna
    2012 te 310
    Thanks for the info I'll be checking valves tomorrow.
  6. nep2012 Husqvarna
    2012 te 310
    Well took my bike over to my friends to check valves on my 2012 te 310 after having what seemed like starter problems. Took advice from threads and guess what the exhaust valve clearance was off put a different shim in which I bought at a local Honda shop and it started right up. Ran it to operating temp shut it down and again it started right up. Through the course of the day sarted up several times without a problem. Seems to be fixed next weekend will be a test when I head out to the New Jersey pine barrens. Thanks everybody for the advice.
    Johnrg likes this.
  7. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
    Just had mine done yesterday on my 2012 te 310 at 1000 miles and my exhaust valve was also out of spec , loose .
