Starter Relay question ( I believe it's dead Jim )
Discussion in '610/630' started by Pinepig, Aug 12, 2013.
  1. Pinepig Husqvarna
    Citrus Heights
    08 610sm
    08 610sm
    Went for a ride yesterday and the magic button had no magic. Turn the key on and the fuel pump does it's thing just like it's supposed to but the starter button doesn't work. Bump started fine and got me home.
    Been out in the shop this morning and Ohm'ed and checked voltage to the ignition switch, starter/kill button and the Starter relay. Everything except for the relay seems to be working as it should. There is no " click " in the relay when the magic button is pressed. Ohmed the wires from the button to the relay and they are fine. Ohmed the small green wire with the resistor to ground and it does what it's supposed when the button is pressed. Power at the other three when the key is on ( fuses are fine ), jump the two main wires on the relay, starter works fine and bike fires as normal.
    Am I correct in thinking that the relay has died?
    Found a part number for a Yamaha relay here, http://www.advrider.com/forums/showpost.php?p=9548599&postcount=10943 Anybody confirm that if I need the relay. ( I know I shouldn't question Indy, hate buying parts that I don't need though )
    Thanks ahead of time.
  2. Pinepig Husqvarna
    Citrus Heights
    08 610sm
