I ride a 2008 Husqvarna TE250. I had a bad spill a few weeks back, bike took a severe tumble down a hill, couldn’t get the bike started after I had recovered from the tumble myself. Problem I have is: Turn on ignition, dash lights up as normal, push full pump button, I hear the fuel pump pressure build up, I then press the starter button only to hear starter solenoid clicking then relay switch under the tank. Tried changing the starter solenoid, still same problem Fuel pump seems to be operating Battery's got a good charge I did manage to get it started after the spill by using the kick start, but the bike only ran for a minute until it seemed to have run out of fuel. Any idea what's up would be greatly appreciated
I bet it is your battery. I had similar problems: http://www.cafehusky.com/threads/te-630-stopped-running-after-a-fall.80473/ I bought 2 Deltran/Battery Tender BTL09A120C batteries and the lithium charger for our '08 TE's. The batteries are MUCH better then stock in every way: http://www.amazon.com/Battery-Tender-BTL09A120C-Lithium-Phosphate/dp/B00F9LPIAC/ref=sr_1_1?ie=UTF8&qid=1435117640&sr=8-1&keywords=battery tender BTL09A120C
