Starting engine other than neutral
Discussion in 'TR650' started by Lawtonco, May 2, 2013.
  1. Lawtonco Husqvarna
    Terra 650 as 3/1/2013
    BMW GSA1200, 2002 Goldwing 1800A
    Has anyone found a set of electrical drawings that would allow the me to override the starting only in neutral default. Kickstand safety is fine but stalling on the trail and then looking for neutral is no fun.
    Steve
  2. macntatsch Husqvarna
    SoCal
    '14 500 EXC, '07 FJR1300
    I'll have to try it again but I'm pretty sure I've killed it at an intersection before (I'll blame it on no MOSS update) and started it in gear
  3. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
  4. blaine.hale Husqvarna
    2013 Terra TR650
    1973 BMW r75, 1974 BMW R90, Bultaco
    You can't just pull your clutch in and hit the start button? Pretty sure I've been in gear, killed it, pulled the clutch in and started.
  5. krussell Strada Adventurer
    Portland, OR
    Strada (for sale)
    K1600 / Super Tenere
    The bike will start in gear if:
    1) your clutch is pulled in
    AND
    2) your kickstand is up
    If you are in gear and the bike thinks your kickstand went down, the bike quits. Sounds like your clutch switch is suspect.
  6. Lawtonco Husqvarna
    Nope, I just tried it again. It will only start in neutral with the kick stand up. It was always like that since I bought it. Is everyone else different?
  7. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Did you fully squeeze in the clutch lever? Sorry for the stupid question.
  8. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    The clutch safety switch is either unplugged or junk.They sll start in gear with clutch in.
    Coffee likes this.
  9. blakebird Husqvarna
    Parker, CO
    '16 FE501S
    '14 Super Tenere
    I had mine refuse to start ONCE in gear with the clutch pulled in - had me scratching my head for sure. It's never done it again, but yes - you probably have an issue with the clutch switch or wiring to it.
    It should start in gear with the clutch engaged and sidestand up.
  10. Lawtonco Husqvarna
    Took it to the dealer and it surprised him also. He tried starting a Strada in gear, clutch in and it does the same for him. ??? I checked my clutch switch and it's working. Nobody else with this?
  11. Wyotr650 Husqvarna
    TR 650
    BMW F800gs, Scopra sy 250 r, wr 250f
    I have had no problem starting mine in gear. I usually leave it in gear when parked on a slant to keep from rolling away. Hold front brake, pull in clutch and start, drive away.
  12. Porkroll Husqvarna
    Tr650
    Honda Silverwing
    Did this issue ever get resolved? I dumped my bike the other day and am having the same issue. Any help her would be appreciated.
  13. johnsweet Husqvarna
    Mount Desert, Maine 04660 USA
    TR650
    KTM 790R RickmanZ BulsSherpaTs350
    did you push the reset button?
  14. Porkroll Husqvarna
    Tr650
    Honda Silverwing
    Twice. Didn't work.
  15. Porkroll Husqvarna
    Tr650
    Honda Silverwing
    Have people done the clutch switch bypass? Does it work? If so, can you give me some direction on how to do this?
