Stator clean
Discussion in '4 Stroke' started by ghte, Apr 17, 2010.
  1. ghte Husqvarna
    Bright, Victoria Australia
    Finally got around to cleaning my stator today. After nearly 4000 Kms it was about time. I had to drop the bash plate and remove the gear lever-no issues there. The stator came off easily. It looked pretty clean but I gave it a once over with some hospital strentgh alcohol wipes. A lot of black gunk came off, it took about 4 wipes to get it clean so that no more gunk came off. After putting it all back the engine fired up straight away-phew. The only down side is that checking over the bike I noticed the roller on the chain guide was frozen. I pulled it off and the bearings just went every where-missed that bit of maintenance-only 20 bucks for a new roller and bearings. Finally the top of the guide was getting pretty cut up by the chain. One trick that works is to fill the grooves/gauges with liquid nails-good as new.
  2. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
  3. ghte Husqvarna
    There is a much better example of cleaning a stator than I could provide (with pics) in the archives.
