TE/TC Stator wiring chafe issue. 2017 250/300.
Discussion in '2st' started by robertaccio, Jun 6, 2017.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    Mikey97D likes this.
  2. Motosportz CH Sponsor
    We have seen this a few times as well. Our 2017 TE250 was fine.
    robertaccio likes this.
  3. Mikey97D Husqvarna
    Connecticut
    TX300
    '08 KTM 250XC; '72 HD Electra-Glide
    This is on my list "To Do" along with kick starter idler gear tap and longer bolt. I have the older cases.
  4. robertaccio Husqvarna
    San Diego, Ca
    I've got 2 gaskets just in case....still have not pulled the cover to inspect.
  5. PawPaw Husqvarna
    2013 TC 449
    Honda Crf450R + old CB750
    Why not just have a good machine shop turn the outer edge of the flywheel down for proper clearance.
    Paw Paw
  6. robertaccio Husqvarna
    San Diego, Ca
    don't want to lighten the flywheel. will do the 10 minute Slavens clearance mods if needed.
  7. robertaccio Husqvarna
    San Diego, Ca
    well mine has just the slightest evidence mark on the outer casing. So it did touch but did not cut in. I did what Jeff did, mixed up some epoxy put it behind the wire bundle and put on a spring clamp until it hardens (hopfully fast!!) I need to finalize prep for tomorrow!
    Cosmokenney likes this.
  8. Mikey97D Husqvarna
    Connecticut
    TX300
    Mine had a very mild mark that the flywheel touched. I just epoxied the harness to the cover too.
    robertaccio and Cosmokenney like this.
  9. robertaccio Husqvarna
    San Diego, Ca
    same kind of set up I did should be good to go....better be ive riding the crap out of it
    Mikey97D and Norman Foley like this.
