Steering Damper for TE610
Discussion in 'Motosportz' started by zoomdude57, Jul 11, 2009.
  1. zoomdude57 Husqvarna
    Seattle
    2009 TE610
    KTM 200XC-W
    Looking for some improved stability at higher roads speeds and hoping not to compromise offroad abilities of the bike. Suspension sag and rebound are now setup and overall bike is pretty stable at freeway speeds. Does get unsettled at 65+ if the road surface is bad or strong winds/traffic.
    Is the Motosportz steering damper and option to settle things out? Have a 09 TE610. Assuming there is a fitment.
    Thanks,
    Paul
  2. rajobigguy Administrator
    So.Cal.
  3. zoomdude57 Husqvarna
    Seattle
    2009 TE610
    KTM 200XC-W
    Can you comment on street performance? Improved stability at higher speeds, etc.
    Thanks for the info.
  4. rajobigguy Administrator
    So.Cal.
    I've had it on so long now that I'm not sure if I remember the exact way it was without it but yes it make a bit of a difference on the street at hwy. speeds. The biggest improvement was in the rougher stuff at moderate speeds and in loose stuff at high speeds. I'm pretty sure that it was instrumental in keeping my rear end from becoming my front end in a few high speed dashes down sand washes.
