125-200cc Steering Head Bearing Nut
Discussion in '2 Stroke' started by PineapplePicker, Jul 21, 2013.
  1. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    2004 Harley-Davidson FXSTI
    Bike is 2013 WR125...
    Clarification: I'm referring to the slotted ring nut that is under the upper triple.
    What size is the steering head bearing nut? I need to go buy a spanner wrench for it. Can anyone point me in the right direction?
    Thanks!
  2. 72racerx Husqvarna
    Melbourne, Australia
    13 WR144
    01 VFR800
    30mm on my WR. Just a side note for you and others if you are ditching the tank vent hose for a smaller one way breather, plug the hole in the top of the steering shaft. If yours has a steering lock, water going down the tube will enter the lower steering head bearing via the steering lock cut out in the tube. I have used Honda part number 53232-MJ4-670 this part is a very good fit and will block most of the moisture going in.
    PineapplePicker likes this.
  3. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    Thanks, 72racerx.
  4. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    72racerx, can you post a picture of the 53232-MJ4-670 part?
    Never mind. Thanks.
  5. HSrider Husqvarna
    Maryland
    Yeah 30mm I had to go add to my tool box the other week bought some sockets and bigger allens for the front axle :)
  6. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    HSrider, where did you get your 30mm spanner. Trying to avoid running all over town to find one.
    Thanks
  7. 72racerx Husqvarna
    13 WR144
    01 VFR800
    Here is what it is
    Forgot to mention earlier this plug will only fit Huskies with the larger inner diameter steering stem.
  8. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    great idea 72racerx! thanks :thumbsup:
  9. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    Thanks 72racerx.
  10. HSrider Husqvarna
    Maryland
    I found the 30mm at Sear's and decided to get a set of 5 bigger sockets in case I needed a different size in the future. I could of bought just the 30mm by itself though.
  11. PineapplePicker Husqvarna
    Henderson, NV
    2013 WR125
    HSrider, so you bought a 30mm socket instead of "C" or "J" wrench. Right?
