Steering head bearings on a Mag
Discussion in 'Vintage/Left Kickers' started by halffast, Jun 18, 2011.
  1. halffast Husqvarna
    East Sparta , Ohio
    Has anyone ever replaced the loose ball type bearings on an MK framed Mag/WR with tapered roller bearings ? I seem to remember a kit for that floating around on the " auction site " a few years back but have not seen it on there for a while . I've replaced the balls a couple of times but the races are getting worn and wears them out pretty fast . They are also a pain to deal with . Is there a source for new loose ball bearing/races if the tapered bearings aren't an option ?
  2. Parh 474 Husqvarna
    Newbury Park, CA
    '73 Cr125, '06 Cr125/144
    Ossa, Bultaco, Puch, Maico, AJS, Yam
    I have a '73 125 that I've shattered the bearings in the lower race a couple of times. I replaced the caged bicycle bearing with all loose bearings minus one and had no more problems. I got loose bearings from McMaster-Carr, they're an inch size - maybe 3/16" from memory. Good quality and cheap. I got extras for the ones that roll down the driveway.
    I remember seeing a kit too, so you're not imagining things. I don't recall who does it though. Huskyjunk has tapered bearings for their super fancy triple clamps, but not for stock.
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    bearings are bearings when it comes to sizes, get the size spec of your oem ball bearings (outer/inner race size) and match it up to a roller bearing set, there are mega choices for sizes there should be a match.
  4. fran...k. Husqvarna
    eastern ct
    I really don't think it is that easy. I have these 1955-1969 bmw bikes which use the total balls all the way full minus one like noted above. One dealer offered me some tapered roller bearings to replace them and I bought two sets, he either got un marked bearings or removed the markings and I never was able to figure out what they were. They also have very timy tapered rollers and I doubt they really are much if any better than what they replaced as far as any property except staying in tact upon disassembly. I expect basically any swap of a loose ball type for another design will not be all that robust.
    Usually with bearings you start with the bore then there are different series basically how much larger the outer diameter is and you can't just pick and choose all your dimentions. Yes some have multiple choices larger of one of the races but I think more space for the rollers not less is what is desired. I have altered bearings both with essentially a tool post grinder and carbide cutters in either a vertical mill or a metal working lathe and it isn't as bad as you might think but of course it is your own safety you play with. If someone has a bearing number for the oigional poster it would simplify matters for them.
    fran
