Steering stop question
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by ptkatoomer, Sep 8, 2013.
  1. ptkatoomer Husqvarna
    San Diego area
    None
    2020 ktm 300 xc-w, 2020 ktm 500exc
    On my TE310 I noticed that I have quite a bit of adjustment left on my stops where I can turn them in much more before the triple clamps would interfere or contact anything before hitting the stops.
    My question is-why wouldn't you want these things adjusted in all the way they can possibly go? Wouldn't you want the tightest turning radius you can get? I can't think of any good reason not to-it's not like it would help keep you from swapping out or anything-I mean, if you're anywhere close to those stops in a bad situation you're hurting already.
  2. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    Not sure, on a stock bike, but on mine I have them backed out a fair way to prevent the handlebar mount to triple clamp bolts from interfering with my steering damper clamp.
    It doesn't affect normal riding, but can be a bit of a nuisance if I'm trying to crank the bars over at low speed, like to turn my bike around in a tight area, etc.
  3. Borgschulze Husqvarna
    2007 TE 610
    2004 Yamaha WR450
    You should try a TE610... very wide turning radius, makes turning around quite the chore in tight places.
  4. organ donor Husqvarna
    Berlin
    A N D the 630. The turning circle defies belief. The bike is as heavy as a grown cow and turns like an oil tanker. Am still waiting for CCM to come up with a 450cc SM so that I can tip the b*gger over a cliff.
  5. organ donor Husqvarna
    Berlin
    Congested inner city riding is comparable with Super Moto. Winding amongst tailbacked traffic needs a tight turning circle ... and an agile bike with lots of backup power (which the 630 definitely is NOT!)
  6. Stepbrother Husqvarna
    USA
    BMW
    The amount of turn before the wheel pushes pass center, the stop helps to keep the bars/wheel from locking/jerking pass center.
