125-200cc stock wr 125 2000
Discussion in '2 Stroke' started by zanol, May 15, 2009.
  1. zanol Husqvarna
    portugal
    hi! im new in this caffe...i bought a wr 125 2000 with new motor but the stock jeting is good for all stock bike? what the best way for test it?
    thanks
  2. Norman Foley Husqvarna
    Welcome! I was going to respond to your PM, but I'll do it here. Stock jetting will work well in cold weather, but is a little rich for 20C temps you mention. Did you get an owners manual? Excellent jetting chart in it. I would install a 390 main (400 stock) and a 32.5 pilot (35 stock) to start with.
  3. zanol Husqvarna
    portugal
    I pulled out my notes from 2002, here is what I was running in the TMX (2002 WR125) back then...
    400 - main
    30 - pilot
    6DJ8-60 - needle
    3rd position - needle clip
    1 1/2 turns out - air screw
    4.0 - slide
    100 Octane rocket race fuel
    50:1 full synthetic spectro premix
    whats the slide?
  4. Norman Foley Husqvarna
    Stock slide was 3.0 (richer).
  5. zanol Husqvarna
    portugal
    norman where is the slide in the carb, its the ralenti?
  6. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    It's the part that the cable attaches to and it slides up and down in the carb body to control air and fuel flow into the motor.
  7. zanol Husqvarna
    portugal
    sorry for my confusion but my its dont my frist language... the air and fuel flow its the air screw, another its the ralenti, the slide I donĀ“t understand, sorry one more time!
  8. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Not A husky carb, but same type of parts for the most part.
  9. Joe Chod Husqvarna
    upstate NY
    Great idea...............picture good..........Frankenstein bad!
  10. zanol Husqvarna
    portugal
    dirtdame you are incredible!thanks a lot but what is 4.0?
  11. Norman Foley Husqvarna
    Mikuni slides have different profiles at the bottom (cutaway), which make the air/fuel mixture richer and leaner. The lower the number, the richer the slide.... 3.0 richer, 4.0 leaner and so on. The number is on the slide. Your '00 should run well, if you use your '02 jetting specs.
  12. zanol Husqvarna
    portugal
    ok norman, I read the importance of jetting in this bike so I want to be a "spec boy"!!!
    my rm 125 95 was easy to jet correct, only hi revs...
  13. Rusty 2 Husqvarna
    Ashland, KY
    I'm thinking you must be pretty incredible yourself zanol.
    I couldn't converse with you in Portugese if my life depended on it,....
    and you have asked a technical question and had it answered!
    I'm guessing you're not just your basic ordinary average guy.
  14. zanol Husqvarna
    portugal
    thanks man... I do evereything in my bike, I like, I prefer and its cheap.
    I dont pay to preparing my bike. my rm shock was rebuilt for me with racetech material...
    I know that everyone here has the same taste that I so..I want to feel I`m driven to heaven!
