I just picked up a 13 Tr650 and have a couple of fueling questions. I am at about 6000ft. and the bike is pretty much stock. When I first turn on the key it says MAP II on the display. I cannot find anywhere it talks about maps for this bike. It seems to have a flat spot, stumble, rough running right at 4000RPM. Any thoughts on this. There is a switch right above the right fork leg that when thrown to the right the temp readout shows the actual air temperature on deg. F and when thrown to the left the readout goes down about 20 deg. Any idea what this might be for? Thanks Marc
OK I found the information on the MAP II as it was only used on the Nuda. DOH! how can I edit my post to remove stupid things. Marc
