If I put a BRP sub mount on to raise the bars 1 inch, will I have problem getting everyhting back on an 07 TE 450? I am trying to be wiser as I age. I ussally buy and then get frustrated that something does not fit or work.
The single attachment BRP tower mount is a weak point. The Husky headstock has several layers of paint which sluffed when I was setting up the damper high speed circuit on the stand. I removed these and then reshot the area with clear coat. Its been fine otherwise with FleXX bars for 7K miles.
