Sub fram bolts catching boots
Discussion in 'General (Main)' started by Bench Racer 117, May 11, 2010.
  1. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    I find that my boots get caught on the sub frame bolts locking my foot on the peg. It's a little scary not being able to get it loose right away. I will replace the brake bolts to match as well. I looked at a hardware store for a round headed allen bolt but they only had it in SAE. Any suggestions.
    I have A-star tech 10 boots.
  2. schrode Husqvarna
    seattle
    i have the same problem with my tech 10's. i was thinking that frame guards may fix the problem....if i could find some.
  3. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    I started trying to build some frame guards, but didn't come up with a good design. Now that you mention it, I think I will try again. If it works, I'll post a picture for you.
  4. schrode Husqvarna
    seattle
    please do.
  5. elbenson Husqvarna
    San Francisco
    2000 WR250
    If you are just looking for the bolts you can find them at McMaster Carr.
    http://www.mcmaster.com
    Just look in the bolt section. Easy to find, fast shipping.
    Eric
  6. Bench Racer 117 Husqvarna
    Oregon
    2007 WR250
    I went to Fastenal and got some Button Socket Cap Screws to match the stock sub frame and brake caliper bolts. Cost $1.30. They should be fine. All I needed was a rounded surface instead of a sharp hex head. They sit closer to the frame too. I'll stick with these and just ride. I started desiging frame guards but thought that the bolts where and easier fix.
    Don't go to Home Depot. They don't have them. Tried a True Value, no luck. You will probably need to go to a specialty store like Fastenal.
