Suggestions on upgrading Headlight on 92-99 4 strokes
Discussion in '4 Stroke' started by JCH4, Oct 29, 2009.
  1. JCH4 Husqvarna
    South Carolina
    Suggestions on upgrading Headlight on 92-99 4 strokes. Need to upgrade headlights on my 1992 350 WXE for a trip. Anyone upgrade to higher wattage? HID? Need to rewind stator? Any advice or suggestions appreciated.
  2. Motosportz CH Sponsor
    Funny and timely as I just looked into this today on my 94 WXC250. It has a robust stock stator that puts out a strong 130 watts AC. To run a HID you need DC. To do that is not simple on this bike. Float the ground, rec / reg etc. It's a custom project. had Trailtech peep mine and said the KTM or other ones do not direct bolt in and would need a custom backing plate.
    So, the best solution IMHO is the Trailtech X2 70 watt Halogen light which is inexpensive and works great. That's what i did. The stator is very strong even at idle and it lights the 70 watt 2 bulb light very well. It works great and your out a grand total of $80.
    Shameless plug, you can oder that right from me at motosportz.com
    I have night ridden with this light on several bikes and it works VERY well.
    here is the headlight on my 94...
  3. JCH4 Husqvarna
    South Carolina
    I want to keep the old school look so I believe I am going to keep the original plastic headlamp and replace the plastic lense with a glass lense unit from Baja Designs. It should be a close fit. Any suggestions on bulb wattage for on and offroad?
  4. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Would the LED Uptite unit work?
  5. JCH4 Husqvarna
    South Carolina
    Good question. Maybe I can get the glass casing/lens from Baja Design and the ask George if the Uptite LED will work on the inside of that.
  6. Ruffus Husqvarna
    Make sure it'll work with ac current, I gotta feeling you'll have the same issue's as with HID. But I could be wrong :lol:
