Suspension Bearings Help
Discussion in 'Vintage/Left Kickers' started by endurokids, Jan 28, 2016.
  1. endurokids Husqvarna
    Wisconsin
    250WRX, CR167, 83 430WR, TE449
    75 Guzzi 850T
    I'm looking for a source to buy my steering head, linkage, and swingarm bearings (complete) for a 1985 250 WRX.
    I'm putting it back together as soon as I get these pieces.
    Thanks guys.
  2. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    Steering head is a standard Timken taper roller and cone available from any good bearing supplier. Swingarm is also a standard SKM needle roller - get double sealed version rather than single seal as OEM. Linkage can be tricky with some spherical balls being a unusual size but can be located with searching on line. You will need to source the various bushes from a husky source - Philip usually has some as I am sure will Andy. Charlie Preston in UK also.
    Remove the bearings, note the numbers and take them to you local bearing shop for sourcing and supply.
    justintendo likes this.
  3. endurokids Husqvarna
    Wisconsin
    75 Guzzi 850T
    Thanks for the reply. I contacted Andy and he is currently out but will have them back in stock in a month.
