Suspension shims
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Bart, May 8, 2014.
  1. Bart Husqvarna
    The Netherlands
    2008 TC450, 2006 WR250
    2009 TM Racing EN300 and EN450
    So why is it that the suspension shims are so expensive?
    Are they different from the ones you could buy in a hardware store (they only cost like 15ct per piece or so)?
  2. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    $1 each might be a lot for a little bit of metal, but it only adds up to 10 or 20 bucks for a full revalve.
    If you can buy the variety of shims you need locally, and they are good spring steel, go for it. I have not been able to find any other sources for shims, besides the suspension suppliers.
    Bart likes this.
  3. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Guaranteed consistency in dimensions.
    Shawbridgehusky and Kyle Tarry like this.
  4. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    How much will it cost when the cheaper shims break, and destroy your forks, or shock?
    Kyle Tarry likes this.
  5. Bart Husqvarna
    The Netherlands
    You don't get the point. I'm just asking if they are different.
    I'm not using them, and wouldn't want to if they are different. As long as the steel is of the same grade I don't see the problem.
    I'm led to believe they are just the same, although most hardware shops wont have them that small.
    Just asking...
  6. Kyle Tarry Husqvarna
    Portland, OR
    I have never seen a hardware shop carry a variety of different diameters for one given ID and thickness. Usually you only get one OD for a given ID.
    Suspension shims (for cyclical bending) are usually made from one or a few very specific materials for that purpose. Shim washers (for spacing) don't have the same requirements, so they may not be made from an appropriate grade.
    Shawbridgehusky likes this.
  7. Bart Husqvarna
    The Netherlands
    See that's useful information!
  8. Fast1 Husqvarna
    Minneapolis, MN
    During my younger years I purchased all the fuel, hydraulic and pneumatic components and misc hardware for a (Northwest Airlines) commercial airline fleet.. and I can tell you those washers are VERY cheap in comparison to FAA certified fasteners and hardware.
  9. Bart Husqvarna
    The Netherlands
    Went to a local suspension shop, they were selling shims for 4,20euro per piece that is (about 5,70usd), thank you but no thanks!
  10. Del Todd Husqvarna
    2013 TC 250 R
    2008 KTM 200 XC, 450 EXC-R
    Over here they cost about $1.00 + or -
