125-200cc Suspension swap
Discussion in '2 Stroke' started by Parfo79, Mar 2, 2013.
  1. Parfo79 Husqvarna
    S Wales, UK
    '98/'05 CR125, '00 CR250
    many...
    Ive got a '98 cr125 which has '05 bodywork. I took her out today for the first time in a few months and the rear shock is junk. There is no damping. Ive also got a '00 cr250 which I bought cheap as it had a broken rear hub and no 2nd gear. Anyway my question is, I know the suspension fits (ive just put the front end from the 250 onto the 125) but how different are the set ups? Is the bike going to handle worse as its all set up for a heavier bike?
  2. DaveG321 Husqvarna
    Easton mass.
    If it bolts on,I can,t see any problem,The suspension from the 250 is well worm by now and depending on your,e weight you should be good to go.With it being winter you should freshen up the suspension before the nice weather arives.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I heard there were different swingarm lengths over the years if that is true measure the swingarm and linkage points before using them
    Parfo79 likes this.
  4. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    Yes, small changes in the rocker gizmo [ bottom shock mount- not all the same] make big changes in ride height and rear fender clearance- likely best to whip the spring off the shock and make sure it has clear travel for the full stroke. The wishbone /dogbone seems to be the same length for the test fittings I have done.
  5. Parfo79 Husqvarna
    S Wales, UK
    many...
    Took bothe 125 and 250 shocks off today and they are identical. Obviously spring rates and internals may differ slightly but the 250 shock will be used as a spare. The 125 shock and 250 forks are going for a rebuild with motopro tomorrow. Happy days.
